axle exchange.
- GuardianAngel
20 Feb 2013 13:29 #63335
by GuardianAngel
Re: axle exchange. was created by GuardianAngel
Might be wrong but would it be legal to remove ABS from a car that was built with it? At very least an MOT failure?
- JivingDaddy
20 Feb 2013 13:52 #63340
by JivingDaddy
Found this quote.
"I've had a quick word with my MOT tester, and he says that he will have to wait until he logs on his MOT computer for my test before he can advise me whether the system has the car recorded as having ABS as standard or optional. He says that if it was fitted as standard, then it HAS to be present and working in the right sequence to pass. If it listed as optional, and is present , it must also work correctly to pass, and fair enough, that's the test!"
Doesn't look promising.
Replied by JivingDaddy on topic Re: axle exchange.
GuardianAngel wrote: Might be wrong but would it be legal to remove ABS from a car that was built with it? At very least an MOT failure?
Found this quote.
- JivingDaddy
20 Feb 2013 13:57 #63343
by JivingDaddy
Replied by JivingDaddy on topic axle exchange.
It seems that way.
If it was optional and has been totally removed then the tester wouldn't know if it was previously fitted (presumably).
- adamjimny
20 Feb 2013 17:05 #63349
by adamjimny
Replied by adamjimny on topic axle exchange.
best way is unplug the abs system via the fuse then remove dash bulb an pop it in for a mot.....if it passes the break test then no problems if they say the abs isnt workin ie stating they know it should have it then just plug it back in and replace bulb
- GuardianAngel
20 Feb 2013 17:30 - 20 Feb 2013 17:31 #63355
by GuardianAngel
Replied by GuardianAngel on topic Re: axle exchange.
As someone who works for a car insurance company, I would say go very careful. If you have a serious accident and have disabled the ABS and gained an MOT out of it, then at best you wont be covered for your own damages.
Worse case you kill someone and your really in the 5hit
Last edit: 20 Feb 2013 17:31 by GuardianAngel.
- adamjimny
21 Feb 2013 00:31 #63481
by adamjimny
Replied by adamjimny on topic Re: axle exchange.
If passes mot and insurance know there is no abs then no problems at all
Sent from my GT-I9300 using Tapatalk 2
Time to create page: 0.090 seconds
