inverter for compressor idea?
  • jimnybob
10 Feb 2013 21:13 #62034 by jimnybob
inverter for compressor idea? was created by jimnybob
im in a debate with myself as to whether i buy an arb compressor setup or run an inverter to a workshop compressor setup? im favouring inverter to workshop compressor as it will be easier and be able to run air tool more efficiently for farm work, but im not sure how (if possible) to connect to arb diff lockers im looking in to buying. cheers guys
  • reaper
10 Feb 2013 21:17 #62038 by reaper
Replied by reaper on topic inverter for compressor idea?
It should work all you need to know is what psi the arb requires and run a regulator on the feed line
  • jimnybob
10 Feb 2013 21:36 #62048 by jimnybob
Replied by jimnybob on topic inverter for compressor idea?
reaper wrote: It should work all you need to know is what psi the arb requires and run a regulator on the feed line
so in the air line that goes to the locker put a regulator that only lets the required amount of air to the locker? this will still allow the air compressor to fully charge without damaging the locker?
  • reaper
10 Feb 2013 21:39 #62051 by reaper
Yes you have a received bottle that holds the pressure from the compressor and that has a limit switch built in
10 Feb 2013 22:05 #62058 by mlines
The problem will be the current that the workshop compressor needs.
The lowest wattage around is the Clarke Mini Air compressor at 99Watts
Other motors are rated in Horsepower and 1HP = 745 Watts.
Small compressors are 1.5 HP and larger DIY ones are 2 or 2.5 HP so between 1000 and 1800watts
The cheapest 2Kw Inverter on Amazon is £160 so an inverter is not a cheap way of doing it.
  • jimnybob
10 Feb 2013 22:18 #62061 by jimnybob
is that an official conversion 1hp = 745watts? if so thats handy to know :) it might be for me as all i need is the inverter
Time to create page: 0.091 seconds
