obd fault code reader
- newbiepaul
31 Jan 2013 19:05 #60420
by newbiepaul
obd fault code reader was created by newbiepaul
Hi guys going to order myself one off the dreaded ebay but just wondering if anyones bought one and what youve got before i go getting the wrong one lol
cheers chaps
cheers chaps
- little jimny
31 Jan 2013 19:29 #60424
by little jimny
Replied by little jimny on topic obd fault code reader
I got one off Amazon. Can't remember exactly which one, but worth having a look - eBay is not always the cheapest place to buy.
- gaz3359
31 Jan 2013 19:35 #60426
by gaz3359
Replied by gaz3359 on topic obd fault code reader
ive got a couple of different ones but recently bought one of these,always got it with me been a mechanic,and so far has worked on every car ive plugged it into all you need if you have an android phone is an app called Torque sync the obd reader via bluetooth activate gps and your away,has alot of features on it very good piece of kit for the money.
www.ebay.co.uk/itm/Android-Torque-ELM327...&hash=item41673a9580
31 Jan 2013 19:54 #60431
by kirkynut
Replied by kirkynut on topic obd fault code reader
I've got the Maxi Trip scan gauge that Martin has and keep it hard wired to my ECU. Not all OBDII readers work in Jimny's - don;t ask me why as I thought OBDII was supposed to work on all readers made for it and that was the point of it!
The extra benefit is that you can see what's going on - such as coolant temperature to the degree - so if it get's a few degrees hotter than usual, you notice straight away - not when it's boiled it's self up and the car's gauge decides to catch up.
It also has a volt meter for the battery on it, so if it goes much below 14.3v you know either the battery or the alternator are playing up - giving you the early heads up before it won't start on you!
The rest of the stuff on it is not much use but I like having it on for the peace of mind and the ability to be able to read codes straight away. Not that mine creates them really! Touch wood!
- newbiepaul
31 Jan 2013 20:55 #60445
by newbiepaul
Replied by newbiepaul on topic obd fault code reader
hmmm cheers guys thanks for the advice ,gaz can you link me that ebay item again as its not shown up
cheers Paul
cheers Paul
- reaper
31 Jan 2013 21:01 - 31 Jan 2013 21:03 #60448
by reaper
Replied by reaper on topic obd fault code reader
Not from this seller but the same one
This is the one i use with my android phone and tablet has stuff that you may never use but loads of cool stuff to as well as a code reader / re-setter
www.ebay.com/itm/120778168943
120778168943
120778168943
Last edit: 31 Jan 2013 21:03 by reaper.
Time to create page: 0.111 seconds
