Headlights
23 Jan 2013 10:22 #59271 by maverick
Headlights was created by maverick
How do you adjust headlight beam and direction?
Since putting on new (2nd hand) headlights, my beam is a little low, even with the self adjuster at zero).
Jalapeño, IISY?
  • Sandspider
23 Jan 2013 12:47 #59279 by Sandspider
Replied by Sandspider on topic Headlights
Not sure about Jimnys as I don't have one (yet!) but on my current car, there are screw heads around the actual light bulb unit / lens (or perhaps around the bulb itself) to adjust the angle... Try that?
  • wanderinstar
23 Jan 2013 13:39 #59284 by wanderinstar
Replied by wanderinstar on topic Headlights
On mine, a 2002 one, they are adjusted up and Down ellectrically. There is a switching right hand. Sie of steering wheel. At about4oclock,. Side to side I don,t know. Sorry
23 Jan 2013 16:05 #59291 by Obarno
Replied by Obarno on topic Headlights
They are adjustable up and down and side to side with a screwdriver. There are 2 slots, one at the top of the back of the light on the engine side, its like a small wheel with teeth inside a plastic housing, and the other which looks the same is on the back of the motor. They seem to take a lot of turning for not much movement which makes it quite easy to adjust them accurately. Sorry cant remember which does which action, but I would imagine the top one is side to side and the one on the motor for up and down.
Time to create page: 0.087 seconds
