Smoking jimny
- ZukracerV6
21 Jan 2013 23:35 - 21 Jan 2013 23:42 #59052
by ZukracerV6
Smoking jimny was created by ZukracerV6
Evening all!
It's been annoying me for awhile now the jimny is fitted with a 1.6 liana engine and seems to run fine but the exsaust is always smoking, not at oily smoke but the type you get on a cold day when the engine is cold? Plus the exhaust always smells like its running rich?
Have a look at the video to see what I mean - September Trial
I have had the emissions checked and been told there ok?
So what are your thoughts?
Cheers
Sam
Cheers
Sam
Last edit: 21 Jan 2013 23:42 by ZukracerV6.
- rs200boy
21 Jan 2013 23:50 #59055
by rs200boy
Replied by rs200boy on topic Smoking jimny
looks awfully white which would suggest water getting into cumbustion
i would get a compression check done on it could be a pin hole in head gasket allowing very little water into cylinders
are you using coolant at all ?
- ZukracerV6
21 Jan 2013 23:54 #59056
by ZukracerV6
Replied by ZukracerV6 on topic Smoking jimny
I have topped it up the other day for the 1st time. It was about 1/2" below the cold fill line. It's has only done a couple of hundred miles in the last 4 months so if its using water it's only used a little bit.
- ZukracerV6
22 Jan 2013 10:41 #59085
by ZukracerV6
I think your spot on with answer as I would describe the smoke more to be steam than smoke!
- adamatdraycott
22 Jan 2013 12:29 #59091
by adamatdraycott
Replied by adamatdraycott on topic Smoking jimny
You often get a sweet antifreeze smell if its the head
Steam is normal on a cold day... along with water (condensation) dripping from tail pipe... but if its constant even when the engine has been warm for a while you could have an issue
- ZukracerV6
22 Jan 2013 21:55 #59198
by ZukracerV6
It's pretty constant so I do suspect it's the head gasket with a very small leak. Another weekend project!
Time to create page: 0.094 seconds
