is it possible to get 2wd low ratio??
09 Jan 2013 08:05 #57595 by mlines
Most vacuum equipped Jimnys run in 2WD low anyway :ohmy: :whistle:
  • Paul4x4
09 Jan 2013 09:24 #57600 by Paul4x4
Replied by Paul4x4 on topic is it possible to get 2wd low ratio??
Or, if you have an SJ t-box, you can have a twin stick shifter that makes it possible to use 2wd low.
  • Cider
09 Jan 2013 09:50 - 09 Jan 2013 10:00 #57602 by Cider
Replied by Cider on topic is it possible to get 2wd low ratio??
Hi
jo king did a write up on here how he done his, not sure how to pin up a link
used "2wd low" and seach "jo king" posts and found it :) Oh the post is over a year old so you`ll have to set your search to any date!!!!
Cheers
Last edit: 09 Jan 2013 10:00 by Cider.
  • wanderinstar
09 Jan 2013 10:41 #57608 by wanderinstar
Replied by wanderinstar on topic is it possible to get 2wd low ratio??
"Most vacuum equipped Jimnys run in 2WD low anyway"
If that is the case Martin, is it possible to convert to 2WD high? How would you know if your vehicle was running 2WD low
I presume you would not be towing your heavy trailer in the road. As I presume if you need 2wd low to tow it, then it must be VRRY heavy.. Be very careful of exceeding the vehicle towing weight.
09 Jan 2013 10:54 #57609 by mlines
WanderingStar - it was a joke based on the fact that most Jimnys have never been in 4WD and the vacuum hubs have probably failed!
As suggested, by putting a switch in the 4WD wire from the transfer box you can stop the hubs engaging and you get 2WD High and Low ratio.
I use a trailer a lot and having the ability to low speed manouver the trailer is really handy. Even with a 3 Litre diesel engine with loads of BHP reversing a 1 tonne trailer up a slope taxes the drive chain in High Ratio. I suspect that I would end up boiling the fluid in the Auto box quite quickly. Therefore being able to use low ratio gets around this. clearly I am not talking about a jimny but the principle is the same - low and slow is good!
  • ITI RIDER
09 Jan 2013 11:05 #57611 by ITI RIDER
Replied by ITI RIDER on topic is it possible to get 2wd low ratio??
reaper wrote: There is a switch in the t-box that activates the vacumme you can splice another dash mounted switch into this , this will let you choose if the front hubs lock or not therefore giving you the option of 2wd low
exactly! The transfer has 2 electonic valves, the front is for the 4wd, and the rear (with a small skid plate) is for the low. If you cut one from to cables (on the front valve) and insert an on-off swith, you can have low in 2wd mode. A good position for the switch is on the side of handbrake. The cable can pass from a hole under the handbrake.
If you do this, take care..
-wich way you engage the 2wd low. You must first engage 4wd, then 4low (as usually) and then take the new swith in "off" mode to have 2wd low mode.
-To go back in 2wd high mode, take the new swhich to "on" and then disengage the 4low and 4wd as usually.
-if for any reason the car switch off in 2wd low mode, before you start you must puss the new swith to "on"
Time to create page: 0.164 seconds
