is it possible to get 2wd low ratio??
- jimnybob
08 Jan 2013 22:38 #57580
by jimnybob
is it possible to get 2wd low ratio?? was created by jimnybob
hello everyone! just wondering, is it possible to make 2wd low ratio on my jimny?? if so how hard is it to do? a build thread would be very helpful :side: the reason i would like to do this is so i can use the jimny to move heavy trailers around but as it on concrete would rather not be in 4wd. thanks in advance look forward to replies
- iloveics
08 Jan 2013 22:49 #57582
by iloveics
Replied by iloveics on topic is it possible to get 2wd low ratio??
Yea it's possible, if you have manual locking hubs. select 4 low, and dont get out and turn the hubs on haha
- jimnybob
08 Jan 2013 22:59 #57585
by jimnybob
Replied by jimnybob on topic is it possible to get 2wd low ratio??
:lol: with the vaccum system pwease. heard something about a switch that stops a vaccum but couldnt find any more :huh:
- winter
08 Jan 2013 23:05 #57587
by winter
Replied by winter on topic is it possible to get 2wd low ratio??
just like matey befor me said you need to have m/hubs have them in the free wheel and pop it into 4wd low your then have 2wd low
but dont think you can do with air hubs get rid of them
- Dave n lincs
08 Jan 2013 23:18 #57589
by Dave n lincs
Replied by Dave n lincs on topic is it possible to get 2wd low ratio??
Can the pipes to the vacuum front hubs just not be disconnected? And then run it in 4 low. Or even remove front prop shaft.
- reaper
08 Jan 2013 23:28 - 08 Jan 2013 23:29 #57590
by reaper
Replied by reaper on topic is it possible to get 2wd low ratio??
There is a switch in the t-box that activates the vacumme you can splice another dash mounted switch into this , this will let you choose if the front hubs lock or not therefore giving you the option of 2wd low
Last edit: 08 Jan 2013 23:29 by reaper.
Time to create page: 0.785 seconds
