engine conservation help
  • winter
01 Jan 2013 14:27 #56782 by winter
engine conservation help was created by winter
hi has anyone done an m16a 1.6 engine conservation on there jimny as need some info
many thanks guys
  • Dave cc
02 Jan 2013 17:20 #56918 by Dave cc
Replied by Dave cc on topic engine conservation help
Dont quoute me mate but dont think you can swap the M series engines about like the G series i beleive that the engine managment cannot be adapted to suit the larger capacity.
With the G series engine you can fit the 1600cc baleno injectors and they will run ok with the 1300cc system.
  • Dave cc
02 Jan 2013 22:22 #56985 by Dave cc
Rich love to know how you get on with the swap have seen this question come up more than once sounds like you have done your homework i have not had any dealings with M series engines only messed with the older G series be good to knowhow it goes
  • winter
03 Jan 2013 17:54 #57063 by winter
Replied by winter on topic engine conservation help
m13a too a m16a it all fits ok picking new engine up in two weeks then crack on getting her in
happy days i spoke to a guy who has done this conservation befor it helps when you talk to people who know what they on about 100% not just read on internet !!!!
ill let you guy know how it gose fingers crossed as this will be the first engine iv ever changed cant wait lol
o and thank to any of you that left a reply
KEEP ON TRUCKING!!!!
  • Bigchridy
03 Jan 2013 18:48 #57072 by Bigchridy
Replied by Bigchridy on topic Re: engine conservation help
I've done this conversion before and it really is easy. Its just a case of swapping all the bits over! Simple!:silly:
The hardest parts I found were:
1) lifting the engine out as you have to go quite high with the engine (especially if you have a big lift!). It will be a lot easier if you take the bonnet off, then you get all the room you need.
2) getting the bottom pulley off the old engine as I had no compressor at home. If you have access to a compressor then use it as it will save you a lot of time and effort.
If your doing the conversion at home and only have basic mechanical skills you should be able to do it in a weekend.
Chris
Sent from my Nexus 7 using Tapatalk 2
  • winter
03 Jan 2013 22:32 #57109 by winter
Replied by winter on topic Re: engine conservation help
hello buddy thanks for reply
taking off bottom pulley is than for the oil pick up ?
Time to create page: 0.104 seconds
