Random Knock From Rear End
  • Jimnyash
01 Jan 2013 14:24 #56781 by Jimnyash
Random Knock From Rear End was created by Jimnyash
It only started yesterday and will do it for a while then stop!
It only happens when braking, there's a metallic sound knock from the OSR corner.
If I brake, it knocks before I stop, pull away, brake and it does it again.
Then, after a 5 minute stop, and drive off, it doesn't do it again!
Any thoughts? Could it be handbrake related?
02 Jan 2013 09:59 #56883 by kirkynut
Replied by kirkynut on topic Random Knock From Rear End
Could be:
Worn bushes in shock or radius arm
Radius arm bolts not tight enough
Prop uj worn
Too much backlash in the diff
Brake shoe lining come un bonded and loose in the drum
Broke suspension spring
Panhard rod bush worn
Transfer box mount or arm worn/snapped
I think this is about all I can think of! You'll have to get under and investigate with this list in mind.
  • JerseyJimny
02 Jan 2013 10:23 #56887 by JerseyJimny
Replied by JerseyJimny on topic Re: Random Knock From Rear End
Something rolling around in the boot? ;)
Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk 2
  • trextr7monkey
03 Jan 2013 00:04 #57009 by trextr7monkey
Replied by trextr7monkey on topic Re: Random Knock From Rear End
Intermittent asylum seeker.
Time to create page: 0.084 seconds
