abs sensor
  • ratman
29 Dec 2012 10:08 #56470 by ratman
abs sensor was created by ratman
Good morning folks, ABS sensors,where can I buy them and are they simple to change? Any how do you know which one is faulty? Symptoms are ABS light coming on then going off? Any advice welcome
  • reaper
29 Dec 2012 11:06 #56475 by reaper
Replied by reaper on topic abs sensor
Could just be gunk on the sensor or cog
Try cleaning both and check the sensor hasnt got bent to far away from the cog :-)
  • ratman
04 Feb 2013 16:16 #60853 by ratman
Replied by ratman on topic abs sensor
thanks iv done that and some how their is a dent in the front sensor, i ended up having to angle grind the bolts of as they were in some nik, where could i get replacement sensor cheapest please! :lol:
  • Northern-Wanderer
04 Feb 2013 21:01 #60906 by Northern-Wanderer
Replied by Northern-Wanderer on topic abs sensor
The only non dealer ones i have found are Euro car parts @ £229 each,they must be solid gold
  • darthloachie
05 Feb 2013 08:34 #60947 by darthloachie
Replied by darthloachie on topic abs sensor
try cam-suzuki
  • ratman
06 Feb 2013 08:10 #61065 by ratman
This is proving not easy, spoke with a chap at suzuki, he said they are bad for the wires cracking not so much the sensor failing, has any one re wired them before? do you need a special reader for reading abs fault? as im aware by looking at service manual that ther is another plug for this,where can you buy a reader from?
All the help above is very welcome ,thanks
Paul
Time to create page: 0.089 seconds
