Engine management light on all the time
  • peter broadbent
26 Dec 2012 05:04 #56227 by peter broadbent
Engine management light on all the time was created by peter broadbent
Engine management light on all the time. Been pluged in at Suzuki they say EGR valve not opening, changed egr valve for second hand one which had no effect, changed both sensors on exhaust and new complete exhaust fittted. Cleaned all pipes on egr system, checked all connections.
Any ideas please!!! (2003 Jimny twin cam engine)
26 Dec 2012 16:13 #56260 by facade
There are 2 ways to monitor the egr valve.
First is a position sensor in the valve. (doubt if the jimny has one)
Second, more likely, the ecu cracks the valve open at idle (when it should be closed) and looks for a disturbance at idle (as in a drop in revs)
This is likely the reason for the odd "miss" at idle that the early twin cams have.
Anyway, if the passages to the EGR are blocked so it doesn't work it will likely fail this test and put the light on.
If the valve sticks open, the idle is lumpy, and the CO readings are up at the pre-cat sensor.
I would clean the valve passageways and the valve itself and reset the light, then as soon as it comes on again read the codes and let us know what they are.
  • peter broadbent
26 Dec 2012 17:19 #56268 by peter broadbent
Replied by peter broadbent on topic Engine management light on all the time
Thanks for your reply, this thing is driving me mad. If I reset the light by disconecting the battery it stays off for two or three short trips then pops on again. I have cleaned the tubes etc, there was nothing in them. The reves do dip sometimes at idle. Suzuki dealer said it might be a broken wire and did not want to get involved further. Can you suggest any thing else i could try
Peter
26 Dec 2012 20:47 #56286 by facade
Get a £20 fault code reader from eBay, then you can read the fault code and reset it at the press of a button.
Could be a wiring fault I suppose, check the wiring for melted or chafed pieces, or being too tight.
  • JerseyJimny
26 Dec 2012 21:29 #56293 by JerseyJimny
Replied by JerseyJimny on topic Engine management light on all the time
Hang on the suzuki dealer didnt want to get involed!?
Talk about shit service...
  • peter broadbent
02 Jan 2013 19:00 #56933 by peter broadbent
Hi, got code reader off ebay, fault code reads po400 "Exhaust gas recirculation flow"
I have cleaned all tubes and checked for free flow, I have changed the EGR valve for one I know to be good and also tested the original one which also tests out OK. The car has a new exhaust, cat and both sensors.
Have reset the light with the gadget and it has come back on after two short trips.
Can any one help? this is driving me mad not to mention the cost
Time to create page: 0.099 seconds
