More torque?
  • Docmartin4x4
04 Dec 2012 21:54 #54858 by Docmartin4x4
More torque? was created by Docmartin4x4
Is there a modification out there that would give me a bit more power, i have be been told that a re map of the ECU is not possible on the Jimny?
Mart
  • supergaz
04 Dec 2012 21:58 - 04 Dec 2012 21:59 #54861 by supergaz
Replied by supergaz on topic More torque?
A friend of mine does re-mapping (Protune) and cannot do my jimny. So the answer is to fit an engine from the Liana as it is the same but a 1.6
This is my job for next year :silly:
Last edit: 04 Dec 2012 21:59 by supergaz.
  • Licksan
04 Dec 2012 22:18 #54869 by Licksan
Replied by Licksan on topic More torque?
1.6 With A Supercharger! :woohoo: :evil:
  • bluejimny
04 Dec 2012 22:18 #54870 by bluejimny
Replied by bluejimny on topic More torque?
some one told me he had his "chipped" before he rolled it and it went well, but didn't ask any more about it so wondering if they can (with certain software)
a quick google reveals you man
Stock ECU is easily reprogrammed using a BDM interface, what I am currently working on is reprogramming using the diagnostic link. The Jimny ECU that I have already looked at has this capability but it is intended for factory use and is not brought out to the front connector although this is a fairly trivial problem. Later ECUs and Spanish ECUs may have the necessary pins on the connector. I haven't published much information on the Jimny ECU yet but here is the page:
www.rhinopower.org/ECUs/81A11/81A11.html
The BDM adapter costs about $10 and the software that is required is free from Psyche on TLzone.net on ECUprojects.com. For modifying maps I use TunerPro RT which is also free.
Denso 3260 injector is 185cc/min @3bar, you would need something like a 3400 to get 250cc/min but you would need to check the fit. There is a guy called ItsDamo on RedlineGTI who ran a turbo on a G16B Baleno, I think he modified his manifold to take Subaru injectors, it would be worth sending him a PM.
Emanage Greddy is a 'piggy-back' unit, it allows limited tuning of the stock ECU by adjusting the inputs and outputs. The problem is that there is a limit to how much you can cheat the ECU before it detects a fault and drops to backup mode.
  • Docmartin4x4
04 Dec 2012 22:37 #54872 by Docmartin4x4
Replied by Docmartin4x4 on topic More torque?
Might be a little over the top.......might just drop my scooby engine in!!!
It's just that i used to do a lot of off roading but always had Land rovers running with V8's and I feel very underpowered. I pick my Jimny up tomorrow, so we'll see then eh!
  • Docmartin4x4
04 Dec 2012 22:38 #54873 by Docmartin4x4
Might just look at that!! Cheers
Time to create page: 0.095 seconds
