Engine Coolant
  • jimnyonhigh
03 Dec 2012 20:22 - 03 Dec 2012 20:25 #54772 by jimnyonhigh
Engine Coolant was created by jimnyonhigh
Hi guys just a quick question regarding the engine coolant in the Jimny
I checked it today and it needs topping up slightly, the coolant is green
Thinking about topping up the antifreeze now winter is fastly approaching but have no idea what antifreeze to put in as a top up, obviously flushing the old stuff out and starting fresh would be the better option but i just want to top up whats already in there.
I understand not to mix colours etc
Cheers
Last edit: 03 Dec 2012 20:25 by jimnyonhigh. Reason: mistakes
  • suzuki jimny fella
03 Dec 2012 20:25 #54773 by suzuki jimny fella
Replied by suzuki jimny fella on topic Engine Coolant
as above :-D was going to ask this an where do you guys drain it from do you take pipe off thanks
03 Dec 2012 20:47 #54775 by facade
Replied by facade on topic Engine Coolant
There is a drain plug at the bottom of the radiator.
Undo it with the rad cap off. (make sure the fluid doesn't spill on the ground as doggies and hedgehogs will drink it and die.) [So will cats, but I don't like them much]
Tighten, and refill, run engine until hot.
Undo and drain.
Repeat until water is clear.
This time add antifreeze, and the job is done.
I used red, as it lasts for a few years, probably damages japanese seals though...
03 Dec 2012 21:11 #54780 by suzuki jimny fella
thanks what spec is the anti freeze for jimny
  • dirtydogz
03 Dec 2012 22:43 - 03 Dec 2012 22:45 #54789 by dirtydogz
Replied by dirtydogz on topic Engine Coolant
Last edit: 03 Dec 2012 22:45 by dirtydogz.
Time to create page: 0.095 seconds
