Dreaded tyre sizes....again....
  • Jimnyadmirer
02 Dec 2012 21:52 #54705 by Jimnyadmirer
Dreaded tyre sizes....again.... was created by Jimnyadmirer
Ok, so I know a lot of you will be sick to the back teeth of questions about tyre sizes by now, Ive had a look through some of the posts here, and cant seem to find the info im looking for!!
have ordered a 1.5" spring spacer kit from bits4vits, and was wondering......how tight will a 235/75/15 buckshot mudder tyre be on a 1.5" lift?? could i get away with it without cutting chucnks out the bumpers??
Just to note, ive already also fitted 32mm spacers front and rear and have just order 15x7 new steel wheels.
your help is greatly appreciated, and thanks in advance!!
Regards
Ian :)
  • mudman
02 Dec 2012 22:47 #54708 by mudman
Replied by mudman on topic Dreaded tyre sizes....again....
you will need to clip the corrners of the archs but it should be fine
  • Jimny J
02 Dec 2012 23:01 #54709 by Jimny J
Replied by Jimny J on topic Dreaded tyre sizes....again....
Not sure if this is the place too bring this up but im also looking to get some tyres asap, as well as a 2in lift. Apart from tyre clearance, there also seems to be a lot of chat about larger diameter tyre's and transfer box gear ratio's. Some people say the larger tyres put too much strain on the trans, yet other seem to be running larger tyres on a standard transfer box with no issues. All seems very confusing if you ask me. :huh:
  • jordy
03 Dec 2012 09:40 #54724 by jordy
Replied by jordy on topic Dreaded tyre sizes....again....
Jimny J wrote: Not sure if this is the place too bring this up but im also looking to get some tyres asap, as well as a 2in lift. Apart from tyre clearance, there also seems to be a lot of chat about larger diameter tyre's and transfer box gear ratio's. Some people say the larger tyres put too much strain on the trans, yet other seem to be running larger tyres on a standard transfer box with no issues. All seems very confusing if you ask me. :huh:
biggest tyre witch the stock drive line is 235-75-15
  • Goat
03 Dec 2012 12:31 #54728 by Goat
Replied by Goat on topic Re: Dreaded tyre sizes....again....
I've been running 235x75s with stock transfer box and I'm in no rush to get a rock lobster. I've done a few pay and plays and been on some Laning trips. Works well.
  • Jimny J
03 Dec 2012 13:40 #54732 by Jimny J
So would 31x10's be too tall? Not sure what a 31 inch equates to in standard tyre sizings.
Time to create page: 0.112 seconds
