predicament
- devgru
14 Nov 2012 00:13 #53200
by devgru
predicament was created by devgru
I'm now at the crossroads that most if not all jimny owners come to at one point in time. Stock or lift?
I wish to maintain the current fuel economy the stock Jimny offers but would like to have that taller stance as well.
Is it possible to have the best of both worlds?
My idea is to get a 2.5 inch lift, change tires to 215/75r15 with non aggressive pattern or street treads.
Any suggestions / opinions / experience are highly sought. Thanks
- ZookFastback
14 Nov 2012 00:31 #53201
by ZookFastback
Replied by ZookFastback on topic predicament
I'd go this way as a good compromise that allows for bigger tyres but not too big and higher clearance but not too much...
37mm lift using original springs and shockers from "bits4vits"
205/70 x 15 Maxxis Trepador tyres, these are same size as original but more aggressive... and look cool too
This way you have enough lift and good gripping tyres that are quite good on the road as well.
- Jimnyash
14 Nov 2012 08:06 #53206
by Jimnyash
I don't know what others have found, but I found as soon as I put on bigger tyres (215/75 15 AT) my MPG went out the window.
It went down from around 35MPG to 31MPG and now the weather is colder it's gone down even more!
Replied by Jimnyash on topic predicament
devgru wrote: I wish to maintain the current fuel economy the stock Jimny offers
- adamatdraycott
14 Nov 2012 12:28 #53217
by adamatdraycott
Replied by adamatdraycott on topic predicament
As Ash says... the cold weather has taken mine down from 32-33 to now just over 30mpg
I'm running 205/75 on stock suspension
- GuardianAngel
14 Nov 2012 13:13 - 14 Nov 2012 13:15 #53222
by GuardianAngel
This will be the route I will take one day. Nice and simple and relatively cheap. And I would fit wheel spacers as well.
Replied by GuardianAngel on topic predicament
ZookFastback wrote: I'd go this way as a good compromise that allows for bigger tyres but not too big and higher clearance but not too much...
Last edit: 14 Nov 2012 13:15 by GuardianAngel.
- jimnycricket
14 Nov 2012 13:43 #53224
by jimnycricket
Replied by jimnycricket on topic predicament
personally tho never lifted a jimny, tho i have on 4 other suzukis , 2 of which i started with a spacer lift
i felt the spacer lift did feel harsh compared with a decent spring lift
so id go with a decent spring lift ....also from bits4vits see his blogs he has it fitted to his own jimny
and he started with a spacer lift i think ...
do it once and be done with . cost more in the long run if you fit spacers now and then feel you
wish you had gone with the spring lift...
my pennies worth
my pennies worth
Time to create page: 0.098 seconds
