LED Headlight Bulbs
  • JerseyJimny
05 Nov 2012 23:05 #52422 by JerseyJimny
LED Headlight Bulbs was created by JerseyJimny
Hi all
Looking to replace all the blubs in the car for LED ones however the dipped and mainbeam are a single bulb (H4 (472))
Now do the LED versions still offer the Dipped/High Beam function?
Cheers
  • ZookFastback
06 Nov 2012 03:25 #52431 by ZookFastback
Replied by ZookFastback on topic LED Headlight Bulbs
Better off going for the H.I.D 35w headlight conversion. Also, LED's inside the headlamps (Parkers) tend to burn out quickly due to the heat from the headlamps.
  • blakey2000
06 Nov 2012 05:49 #52433 by blakey2000
Replied by blakey2000 on topic LED Headlight Bulbs
it is possible to get a LED Headlight, BUT they are no where near as good as HID for headlight bulbs. better off going a moving beam H4 HID kit. Less heat better efficiency more light
  • mudman
06 Nov 2012 15:18 #52464 by mudman
Replied by mudman on topic LED Headlight Bulbs
iv never heard of a LED head light bulb before have you got a link & HID's will fail a UK MOT now unless....
1.fitted as standard
2.the car has self levelling head lights
3.the car has headlight washers
4.the car is not softly sprung
  • GuardianAngel
06 Nov 2012 16:42 #52475 by GuardianAngel
Replied by GuardianAngel on topic Re: LED Headlight Bulbs
GuardianAngel wrote: iv never heard of a LED head light bulb before have you got a link & HID's will fail a UK MOT now unless....
I have read/heard this too.
Sent from my GT-I9100 using Tapatalk 2
  • Beano
06 Nov 2012 17:05 #52479 by Beano
Replied by Beano on topic LED Headlight Bulbs
I had HIDs on my Mk1 Toyota MR2(1988)...
ONLY reason they failed the MOT was because the nearside bulb carrier seized and wouldnt 'pop out' for full-beam
The tester said that had the bulb worked as it should then they would have passed no problem.
Time to create page: 0.118 seconds
