Jacking and supporting
- Carrow
30 Oct 2012 11:07 #51663
by Carrow
Jacking and supporting was created by Carrow
Hi,
Need to Jack up jimny to change Gear, diff, oil etc. Can the jimny be supported on 4x Axle stands at each end of the axles so its Level, or is a combination of front wheels on Ramps, rear on Axel stands needed. My Jimny is not Lifted via suspension etc. (Standard Jimny).
- Sponnie
30 Oct 2012 12:41 #51665
by Sponnie
I can't see a problem on level ground, but I'd be tempted to do the front, lower, then jack the rear.
Replied by Sponnie on topic Jacking and supporting
Carrow wrote: Hi,
30 Oct 2012 12:44 #51666
by facade
Replied by facade on topic Jacking and supporting
Yes you can put axle stands under the axle tubes, be careful that jacking it up doesn't make it topple, but the oils can be changed with the car on its wheels, no need to lift it up.
Access from in front to get the front axle, behind to get the rear axle, and drivers side to do the transfer and gearbox.
The following user(s) said Thank You: Carrow
- Smoggy
30 Oct 2012 20:17 #51696
by Smoggy
Replied by Smoggy on topic Jacking and supporting
Yeah like Facade said be careful it doesn't topple as the diffs are offset. I toppled mine a couple of weeks ago and twisted my Halfrauds trolley jack at the same time.
Luckily the front wheels were still on and it landed on the passenger front wheel just before it hit my Beemer :ohmy:
- Dutchjimny
30 Oct 2012 20:34 #51701
by Dutchjimny
Replied by Dutchjimny on topic Jacking and supporting
Tipping over? Cant you just jack it up under the diffhousing? And then place axle stands?
- Smoggy
30 Oct 2012 20:44 #51706
by Smoggy
You can but you still need to be careful you get the jack squarely under the diff as it can easily slide off. Then because the diffs are offset it will tip over.
Time to create page: 0.101 seconds
