Cleaned the Polycarbonate Headlights today
- ZookFastback
27 Oct 2012 03:59 #51385
by ZookFastback
Cleaned the Polycarbonate Headlights today was created by ZookFastback
Cleaned the polycarbonate headlamps on my Jimny today. Only spent 5 minutes on each and got rid of the yellow tarnish. Haven't done a perfect job cos my visitors were whinging about abandoning them. Mind ya, they hadn't rung before they lobbed and I had planned to do this job.
I used about a half inch of toothpaste on each headlamp. Washed the lamps first with soapy water then spread the paste and rubbed for a couple of minutes, varying the direction of rubbing, sideways then up and down then diagonally. After a couple of minutes each I then wet the rag and wash for another minute then cleaned up with clean water. Very happy with the job, 11 years of yellowing has gone and I can't stare into the lights anymore so they are putting out plenty of light.
- phippj1
27 Oct 2012 16:12 #51430
by phippj1
Replied by phippj1 on topic Cleaned the Polycarbonate Headlights today
Hi, was that the inside or out side you cleaned, as mine are going manky on the inside? Didnt know if you could get the lamps apart to clean the inside?
- JerseyJimny
27 Oct 2012 17:31 #51442
by JerseyJimny
Replied by JerseyJimny on topic Cleaned the Polycarbonate Headlights today
Most lamps are usually a sealed unit
- Sponnie
27 Oct 2012 17:35 #51444
by Sponnie
Replied by Sponnie on topic Re: Cleaned the Polycarbonate Headlights today
I did mine with Tcut then a coat of polish. Same as you got them back to clear and no yellowing. Top job.
A must do job for winter.
Sent from my GT-I9300 using Tapatalk 2
- phippj1
27 Oct 2012 19:33 #51458
by phippj1
Replied by phippj1 on topic Re: Cleaned the Polycarbonate Headlights today
Did you do the inside or outside of them? As mine are yellow but looks like its on the inside
- Sponnie
27 Oct 2012 19:45 #51461
by Sponnie
Outside. The lights are probably sealed as said.
Time to create page: 0.227 seconds
