front top shock nut ?
- nicho
24 Oct 2012 19:45 #51192
by nicho
front top shock nut ? was created by nicho
having to grind the front top nuts off now,is the large washer type thing on top of the rubber screwed on,(standard ones) there is a nut at the top then another nut but did not no if the 2nd nut was attached to the large washer,ta
- Smoggy
24 Oct 2012 20:58 #51199
by Smoggy
Replied by Smoggy on topic front top shock nut ?
First and from the top down over you have the top nut which is actually a locknut for the one below, this holds down the domed washer which in turn keeps the rubber compressed. When you undo the top two nuts the shocker thread should just pull through.
Sometimes you have to hold the shocker to stop it turning especially if you have already removed the bottom mounting.
If you are doing this be careful you dont have your hand straddling the upper and lower sections of the shock absorber as the release in pressure when you remove the nuts can cause the unit to close up and trap your skin! I learned this from painful experience
- nicho
24 Oct 2012 21:38 - 24 Oct 2012 21:39 #51206
by nicho
Replied by nicho on topic front top shock nut ?
owch...thanks ,so the washer is not connected to the nut,tryed alsorts to undo it and chucking the old shocks anyway so im just guna chop them off tomorow.
Last edit: 24 Oct 2012 21:39 by nicho.
- Smoggy
24 Oct 2012 21:39 - 24 Oct 2012 21:41 #51208
by Smoggy
Thats correct washer not attached to nut(s). Why wont the nuts undo. Is the whole shock turning or are the nuts rusted on?
Last edit: 24 Oct 2012 21:41 by Smoggy.
- nicho
24 Oct 2012 21:45 - 24 Oct 2012 21:46 #51209
by nicho
rusted, cant turn the nuts without the rod beneath turning,tried heat,mole grips n rounded em off now anyway.
Last edit: 24 Oct 2012 21:46 by nicho.
Time to create page: 0.088 seconds
