Different sized spare
  • Raithrover
17 Oct 2012 18:31 #50598 by Raithrover
Different sized spare was created by Raithrover
Originally was going to buy new but a fortnight in Portugal and 'I came home with a brand new plan'. Bought a 2007 with 17.000 on the clock from a Suzuki dealer and discovered the brand new spare tyre is a 195 Dueller while the fitted tyres are 205's Duellers.
Do I have any grounds for complaint and what are they? (Need ammo to tackle the dealer !)
  • reaper
17 Oct 2012 18:33 - 17 Oct 2012 18:34 #50599 by reaper
Replied by reaper on topic Different sized spare
What is the ratio on both tyres ? It may be a different width but work out the same rolling diameter, if that is the case its only the same as having a space saver type
Last edit: 17 Oct 2012 18:34 by reaper.
  • markyp2000
17 Oct 2012 18:33 #50600 by markyp2000
Replied by markyp2000 on topic Different sized spare
205............?
195............?
i would complain it must not have been checked correctly when thay did a check over before you had it if thay did one that is
  • markyp2000
17 Oct 2012 18:37 #50601 by markyp2000
reaper wrote: What is the ratio on both tyres ? It may be a different width but work out the same rolling diameter
it still dont make it right cos if he hadnt noticed it was the wrong size and seeing that it is not a space saver if it was fitted and had an mot it would fail and if you got stoped by the police and he had had a sh*t day he would do you for it and even if vosa puled you over you possably wouldnt be able to drive it away un less it was changed
  • reaper
17 Oct 2012 18:47 #50604 by reaper
Realy ?
My spare is a 235 85 16
Whereas rest are 265 75 16
All work out about 31.5"
  • markyp2000
17 Oct 2012 18:56 - 17 Oct 2012 18:57 #50608 by markyp2000
mot and police dont look at it that way me being an mot tester if it was on the car so 3 of one size and 1 of another then it would fail and im shore the police would say some thing about it if that saw it
Last edit: 17 Oct 2012 18:57 by markyp2000.
Time to create page: 0.099 seconds
