Head Unit
  • JimnyDan
26 Sep 2012 20:03 #48919 by JimnyDan
Head Unit was created by JimnyDan
Has anyone upgraded the head unit in the jimny? If so how easy is it..
Im only really looking to be able to connect my iPhone/iPod.
If anyone could help id appreciate it greatly :) Thank you.
  • little jimny
26 Sep 2012 21:09 - 26 Sep 2012 21:15 #48937 by little jimny
Replied by little jimny on topic Head Unit
Are we talking early car with a standard single DIN stereo, or a later car with the new dash, push button 4WD and custom fit double DIN stereo?
EDIT - just seen your other posts, so seeing as your car is on an 04 plate you'll have the early dash and single DIN stereo. That's pretty good news as you can just remove whatever is there at the moment and replace it with any single DIN stereo that takes your fancy. Removing whatever is there just now may require the appropriate removal keys (cheap and freely available from eBay), or if the fitting cage hasn't been installed particularly well it may just pull straight out. A photo of what you've got would help if you want more specific advice.
Last edit: 26 Sep 2012 21:15 by little jimny.
  • JimnyDan
26 Sep 2012 21:16 - 26 Sep 2012 21:22 #48938 by JimnyDan
Replied by JimnyDan on topic Head Unit
Sorry i should of stated that, shes an 04 reg and currently has the standard single DIN clarion stereo
EDIT:
Just saw your edit, will nip out now and grab a photo - but all sounds good at the moment :)
Last edit: 26 Sep 2012 21:22 by JimnyDan. Reason: updated info
  • JimnyDan
26 Sep 2012 21:23 - 26 Sep 2012 21:33 #48940 by JimnyDan
Picture as requested :)
Does that mean something like this will fit?
www.caraudiocentre.co.uk/product_m-jvc-kd-x40_p-27475.htm
Last edit: 26 Sep 2012 21:33 by JimnyDan.
  • little jimny
26 Sep 2012 21:35 #48941 by little jimny
Mine had an aftermarket Sony thing which removed easily by just pulling it out - whoever had fitted it hadn't bothered to bend back the fixing tabs! If it is a standard fit unit put in at the factory then it's probably a different matter.
To deal with that you need to remove the front dash surround that goes around the stereo and ashtray. First, remove the ashtray. Look up from the gap and you'll see two screws - remove them. Next, look at the very bottom of that surround and remove the two screws there. Finally there is one last screw at the very top in the middle to remove. The frame will now unclip to reveal another frame that houses the stereo, clock and cubby. There are two screws on either side of this that you need to remove to allow you to slide it forward out of the car. There are holes in the side of this that I would guess are used to bolt in the standard factory stereo - it will be obvious if this is the case. You could bolt the new stereo in place using the same bolts and holes, or you can reassemble the car and then use the fitting cage the stereo comes with.
My Jimny already had ISO connectors in place and they looked to be factory fitted. If you have the same then it will be childs play to hook up the wiring and there is plenty of room around the back of the stereo for the wiring (unlike a lot of cars I've changed stereos on!). If you don't have the ISO connectors then you can pick up an ISO adapter harness thing off eBay for a couple of quid.
  • little jimny
26 Sep 2012 21:39 #48943 by little jimny
JimnyDan wrote: Picture as requested :)
Ha! Just seen this after my last post!!! Looks like you could probably just unclip the trim from around the stereo and then use release keys to get the stereo out. The JVC you linked to is standard single DIN size so it will fit no bother.
Time to create page: 0.095 seconds
