Damaged SJ Flange
- Smoggy
15 Sep 2012 15:12 - 15 Sep 2012 15:19 #48141
by Smoggy
Damaged SJ Flange was created by Smoggy
I tried removing my sj rear output flange today so that I could fit my xbrake backplate. Against my wishes my mates advised welding a piece of angle bracket to the flange to hold it still whilst removing the flange nut. It broke away and pulled away a small amount of metal from the flange too:-(
We eventually managed to shift the nut using Martins recommended method in the "how to guide" (which I suggested in the first place).
My question is, does anyone think the chipped metal will affect the spinning prop balance, is it advisable to weld 2blobs of metal over the chips and grind back to the original shape to restore balance?
Failing this does anyone have a rear output flange with toothed speedo wheel I could buy.
Www
Www
Last edit: 15 Sep 2012 15:19 by Smoggy.
- Paul4x4
15 Sep 2012 15:22 #48143
by Paul4x4
Replied by Paul4x4 on topic Damaged SJ Flange
I wouldn't be too worried. These things are no high precision machinery, so the prop itself probably isn't perfectly balanced either... :laugh:
- markyp2000
15 Sep 2012 15:36 #48146
by markyp2000
Replied by markyp2000 on topic Damaged SJ Flange
i wouldnt either. also that looks like its cast metal and you cant weld to well to that
15 Sep 2012 17:32 #48149
by facade
Replied by facade on topic Damaged SJ Flange
Take no notice, of the gouges or your mates
Next time, drill 2 holes in the angle iron and bolt it to the flange.
- Smoggy
16 Sep 2012 08:04 #48176
by Smoggy
Replied by Smoggy on topic Damaged SJ Flange
Yeah your right Facade I should have gone with my first instincts. I don't fully blame my mates though as they're usually a great help and after all I did agree to weld it after they suggested it
- darthloachie
17 Sep 2012 16:12 #48256
by darthloachie
Replied by darthloachie on topic Damaged SJ Flange
ORA do an SJ rear flange if thats any good
www.offroad-armory.com/store/index.php?r...20_71&product_id=216
Time to create page: 0.225 seconds
