lobster box
- vitara_mad
are you sure its not the clutch ????
- Rockwatt
vitara_mad wrote: check to see if there is any play in the flanges where the props bolt on & if there is check the nut has been tightened up & locked
If the tcase bushes all look good and don't move with a pry bar then check the rear gearbox mounting.
a bearing wouldn't normally cause a judder ! It's more likely a mount gone or the gear teeth badly worn. I've scrapped loads of boxes that I've bought for lobsters due to worn gears.
- Rockwatt
MysticRich wrote: Hi all thanks for the advice. I had already checked and changed most of the options all props and flanges were checked and balanced about 6months ago it has ora mountings just fitted brand new clutch this week along with new rear gearbox mount and the only thing I can find worn are the rear shock bushes. It sounds like the movement is in the transfer box as I remove the gator to see what's happening and can hear the gears rubbing when I take my foot off the gas and it slows down could this be caused by the top bearing being worn
It could be but I'd put money on it that it's the counter shaft needle bearings.
