Diff question
  • ZookFastback
07 Sep 2012 10:11 #47715 by ZookFastback
Diff question was created by ZookFastback
I've been searching the boards to find out the diff ratio of an October 2000 build Jimny rag top but not with much luck. Does anyone know what is compatible with my Jimny? Mine has died, not with a whimper but with a big bang :dry:
  • dirtydogz
07 Sep 2012 17:46 - 07 Sep 2012 17:47 #47739 by dirtydogz
Replied by dirtydogz on topic Diff question
Good site to work out diff ratios, tyre size, corrected speedo reading and so on ...
www.snoman.com/HTML/axlecalc_5a.html
Last edit: 07 Sep 2012 17:47 by dirtydogz.
07 Sep 2012 20:40 #47764 by Obarno
Replied by Obarno on topic Diff question
I think there has been some discussion on diff ratios before and it seems tha the Oz cars use a different ratio from the UK cars. If it was a UK manual it would be 3.9, or 4.01for an auto. I think if you search the forum you will find the answer. Sorry not to be any more help.
  • ZookFastback
07 Sep 2012 22:31 #47771 by ZookFastback
Replied by ZookFastback on topic Diff question
It's a Spanish build Jimny, from Santana Motors.
  • dirtydogz
08 Sep 2012 07:55 #47781 by dirtydogz
08 Sep 2012 08:18 #47783 by Obarno
I think that if it is Oz spec, which I would imagine it would be ie rh drive, but km, speedo, and not an auto or vvt it would be 4.09. Sorry I made a mistake in the original comment and the 4.01 should be4.09. Perhaps your best bet though would be to count the old diff crown wheel and pinion teeth if they are in a suitable state!
I had forgotten that a lot of the old threads have disappeared in the update of the forum.
Maybe someone on an Australian forum could confirm the above.
Good luck!
Time to create page: 0.129 seconds
