HELP! Fuel gauge.
  • Mala43B
05 Sep 2012 16:16 - 05 Sep 2012 16:21 #47545 by Mala43B
HELP! Fuel gauge. was created by Mala43B
My fuel gauge is not returning to empty when the ignition is off however if i manually turn it to empty and switch on the ignition it will rise to show how much fuel I have in the tank.
what could be wrong here and where should I look first?
Has anyone had any similar problems?
Picture below showing fuel gauge with just under 1/4 tank left however the ignition has been off for an hour.
Last edit: 05 Sep 2012 16:21 by Mala43B.
  • Paul4x4
05 Sep 2012 16:21 #47546 by Paul4x4
Replied by Paul4x4 on topic HELP! Fuel gauge.
I'm not sure, but I think mine does the same...
But what's the problem really? I couldn't care less what it says when the truck is parked as long as it works like it should when I drive it! :laugh:
  • Mala43B
05 Sep 2012 16:25 #47548 by Mala43B
Replied by Mala43B on topic HELP! Fuel gauge.
Thats just it, it doesn't seem to go down at all.
05 Sep 2012 16:46 - 05 Sep 2012 16:49 #47550 by facade
Replied by facade on topic HELP! Fuel gauge.
Japanese electrics. It is supposed to be like that. The reading will only change with the ignition on. My Suzuki GSX750 was exactly the same. The RAV4 does it as well.
Last edit: 05 Sep 2012 16:49 by facade.
  • markyp2000
05 Sep 2012 16:57 #47551 by markyp2000
Replied by markyp2000 on topic HELP! Fuel gauge.
so does mine or are you saying it dont move down after you fuel it up and then us the fuel
  • Mala43B
05 Sep 2012 16:58 #47552 by Mala43B
facade wrote: Japanese electrics. It is supposed to be like that. The reading will only change with the ignition on. My Suzuki GSX750 was exactly the same. The RAV4 does it as well.
But it has always read empty when the ignition was off until now.
Time to create page: 0.120 seconds
