I am hoping someone can help me with this - I have read a lot of posts but can't find anything close so here goes:
Have had a Jimny for 6 years during which time the engine management light has been on constantly. There have been no running problems and has passed Mot every year with no problem as far as emisssions concerned. My concern now is that it will fail the test just because the light is on - is that the case? Does anyone have any idea why this light could be on but there be no obvious problems??
The warning light part of the test is being "phased in" this year, it hadn't come into force (along with the steering lock having to work etc.) when I asked at my MOT last month, so it might pass- why not ask at the test station you will use?
Best to get the EML put out though.
If you know the radio code, just disconnect the battery for 5 minutes, this should put it out, but if there is a fault, it will simply come on again.
Depending on the age of the car and the engine fitted, you might be able to buy a £20 device to plug in that will read the stored fault code, and reset the light. On an old car, you can use a piece of wire to make it flash the EML in a number code.
Or you can ask an independent garage to read & reset the codes, but this will cost around the £25 anyway.
The fault could be anything to do with the engine.
Essential Always on
Necessary for the operation of the website. These cookies cannot be disabled.
Functional
Enable convenient features and the storing of preferences.
Statistics
Help us understand how visitors use the website (audience measurement).
Marketing
Used for advertising and tracking visitors across websites.
