Steering Wobble
  • lukeyblunt
29 Aug 2012 18:10 #47054 by lukeyblunt
Steering Wobble was created by lukeyblunt
Evening all !
I just recently hit a curb hard enough to dent the front nearside rim and warp the tyre.. :pinch: resulting in crazy wobble on the steering wheel and gearsticks while accelerating and decelerating through 40-50mph.
I swapped the wheel with one from the back to see if it would make a difference in the wobble.. but it doesn't. :unsure:
What could be the problem..?
Thanks all,
Luke
  • supergaz
29 Aug 2012 18:33 #47057 by supergaz
Replied by supergaz on topic Steering Wobble
May have damaged a Kingpin bearing. Jack the front up and see if the wheel wobbles top to bottom.
  • lukeyblunt
29 Aug 2012 18:48 #47060 by lukeyblunt
Replied by lukeyblunt on topic Steering Wobble
Hi Gaz,
Thanks for your response.
I've just done so and there is no wobble whatsoever.
I need to stop by a garage for some new tyres at the weekend.. so hopefully I'll find out then..
..but any more input would be greatly appreciated!
Thanks again!
  • markyp2000
29 Aug 2012 18:52 #47061 by markyp2000
Replied by markyp2000 on topic Steering Wobble
your rear tyre you put on the front could be out of balance and giving the same feeling
  • lukeyblunt
29 Aug 2012 18:56 #47062 by lukeyblunt
Hi Mark,
Good call but I've only recently had all the tyres balanced !
Haven't a clue what it could be.
.. Perhaps something to do with the steering..? :blink:
Cheers!
  • supergaz
29 Aug 2012 19:09 - 29 Aug 2012 19:10 #47064 by supergaz
Might be a damaged track rod end?
Here was my cause of death wobble at 20mph, Expect this with special tracs, now i've been upto 70mph downhill :silly: and no wobble
This was out of the wheel balancers parameters and shook it to bits, so took some guess work. :pinch:
Last edit: 29 Aug 2012 19:10 by supergaz.
