Speaker Upgrade
- v8dougie
01 Aug 2012 14:04 #45238
by v8dougie
Speaker Upgrade was created by v8dougie
Thought I would post it for peoples info...
HALFORDS
I have just installed the above speakers into the front of my JimJam to replace the one remaining working original speaker. My goodness what a difference!
Just thought I would let you all know in case you were after a quick and cheap and cheerful upgrade. Of course it still depends on WHAT music you listen to as to whether it sounds any good or not!!
Also, the wiring is in the back for rear speakers, it is a rear seat out and side panel off job but not too difficult. They are made to take 10cm (4") in both the front and back, but apparently 13cm ones will fit in the rear with a bit of jiggery pokery.
HTH
HALFORDS
HTH
- JimnyX19
01 Aug 2012 14:50 #45246
by JimnyX19
Replied by JimnyX19 on topic Re: Speaker Upgrade
Yeah they are good brand and good price I have made a boot compartment in my jimmy got two 6x9s pioneer 330w each on top, also have two kenwood subs 600w each at front coming off a alphine amp , with the sub I have added a switch so can turn it on/off to suit the music , looks really neat tho
- little jimny
01 Aug 2012 14:52 #45247
by little jimny
Replied by little jimny on topic Re: Speaker Upgrade
How easy is it to get at the front speakers? is it just one piece of trim to unclip?
- v8dougie
01 Aug 2012 15:05 #45248
by v8dougie
Replied by v8dougie on topic Re: Speaker Upgrade
Yep.
Just in front of the doors underneath the dash, there is the speaker grill. At the bottom of the grill, slightly towards the front there is a plastic cross head screw. Turn it anticlockwise through 90degrees and it should come out a bit, then just pull it out with your fingers. There is another plastic trim which runs along the top of the door sill, gently prise this off, I put all my fingers underneath the inner edge of the trim at the front end and fairly sharply pulled up and the plastic rivets pop out. Pull this off. Then the speaker grill trim will pivot off backwards towards you.
There are two cross head screws holding in the feeble 10w factory speakers and a connector with female spade terminals. I crimped on some male connectors to the end of the wires that came with the speakers and hey presto all working.
HTH
HTH
Time to create page: 0.082 seconds
