New alloy wheels
  • v8dougie
27 Jul 2012 23:27 #45005 by v8dougie
New alloy wheels was created by v8dougie
Well I have just won myself these on fleebay www.ebay.com/itm/180931021720
Now, will they fit! The seller says they are off a Vitara originally. He did the crud measurement across the alloy inner rim to inner rim and said it was about 8 inches, and he said the tyres sit at about 9 inch wide including rubber. They have quite and offset as can be seen in the pic.
I currently have 30mm spacers on, assume they will have to come off?
Any past experience much appreciated!
Cheers
  • little jimny
28 Jul 2012 10:11 #45012 by little jimny
Replied by little jimny on topic Re: New alloy wheels
I haven't seen those on a Jimny (but I think I will do soon when you post pics up!). If they've come off a Vitara they should be fine as far as the PCD and centre bore goes. Seeing as you've bought them you might as well just go pick 'em up and trial fit them. You can always sell them on in the unlikely event they're not suitable.
  • darthloachie
28 Jul 2012 15:29 - 28 Jul 2012 15:38 #45017 by darthloachie
Replied by darthloachie on topic Re: New alloy wheels
they are what supergaz has on his - they will fit :)
Last edit: 28 Jul 2012 15:38 by darthloachie.
  • JimnyX19
28 Jul 2012 15:54 #45018 by JimnyX19
Replied by JimnyX19 on topic Re: New alloy wheels
If all else fails I have a set of 4 oz alloys for sale off my jimny with tyres for £150 exc conditon
  • v8dougie
30 Jul 2012 21:05 #45117 by v8dougie
Replied by v8dougie on topic Re: New alloy wheels
Excellent guys thanks for the responses, including the pic and the cheeky bit of sales!
They have arrived. Need a GOOD clean, but are very straight (or round) so that is a good start.
Couple of questions, what nuts do I need to hold them on, can I use my current ones holding my steels on?
There are centre caps with them, but the little holes for the locating screws have all but broken off, also they have the Daihatsu "D" on them, any suggestions for a replacement?
Finally, they are 7x15 rims, will my Bridgestone Duellers 205/70 r15's fit on? Tyres on at the moment are 225/70's but they are all different and not in very good condition though legal.
Cheers
  • little jimny
30 Jul 2012 21:40 #45119 by little jimny
Provided your current wheel nuts sit correctly in the wheel bolt recess you should be fine to use them. There are two different types of nut - tapered and radiused. Thinking back to when I last changed my wheels I think standard Suzuki nuts are radiused but I'm sure someone will come along and correct me if I'm wrong.
For the centre caps I would leave the front ones off and use your standard black Suzuki ones on the back. I think those wheels are originally form a Daihatsu Sportrak, hence the current caps.
205/70/15s will be fine on a 7" wide 15" rim.
Time to create page: 0.112 seconds
