prop spacer
  • sully
15 Jul 2012 09:21 #44174 by sully
prop spacer was created by sully
as above i ordered a 12.5mm front prop spacer when i ordered my new radius arms but i was just wondering do i fit near the front diff or near the tbox hopefully some one can help
  • markyp2000
15 Jul 2012 10:25 #44179 by markyp2000
Replied by markyp2000 on topic Re: prop spacer
tbox
  • sully
15 Jul 2012 13:01 #44189 by sully
Replied by sully on topic Re: prop spacer
Cheers had a feeling it would be there but it's better to check :)
  • Basketcase
15 Jul 2012 13:40 #44190 by Basketcase
Replied by Basketcase on topic Re: prop spacer
Do you need prop spacers if you just lift the jimny or is the spacer for some other reason?
  • dirtydogz
15 Jul 2012 16:22 - 15 Jul 2012 16:32 #44198 by dirtydogz
Replied by dirtydogz on topic Re: prop spacer
No Basketcase you don't need to fit prop spacer with a 2"or 3" lift with standard radius arms just correction bushes,you will only need a prop spacer when you fit correction radius arm with a 3"or 4.5" lift.
Last edit: 15 Jul 2012 16:32 by dirtydogz.
Time to create page: 0.091 seconds
