Parts arrived!!
  • poacher
25 Aug 2010 16:48 #4399 by poacher
Parts arrived!! was created by poacher
Many thanks Martin, spot on service.
Just out of interest, who do you all use for aftermarket parts? Run of the mill stuff, exhausts etc etc?
Plan to do the pin bearings on Friday, so it's bound to pi$$ down!! (Can't fit it into the garage yet!
Cheers
Dave
26 Aug 2010 05:09 #4402 by mlines
Replied by mlines on topic Re:Parts arrived!!
I use whoever is cheapest. In general my local motor factors is ok or I search online for parts.
I have not had to buy an exhaust yet but people have had problems locating exhausts at reasonable prices.
  • poacher
26 Aug 2010 16:31 #4412 by poacher
Replied by poacher on topic Re:Parts arrived!!
Changed the bearings today, only took about an hour, most of the time was spent cleaning the sludge off!!
Hub nuts a bit of a pain in the backside, might have to make a socket up for that.
Just thought I'd share some pics of the state of the bearings, top set are on the right.
May have to find a supplier for new swivel housing bolts, mine have nearly had it, god bless the Irwin set!!
Cheers
Dave
26 Aug 2010 16:38 #4413 by mlines
Thats interesting, this is the second set I have seen with what looks like some sort of attempt at sealing the bearing. Someone else has also mentioned that sealed bearing seem to exist.
When I took up selling the Kingpin Bearings I bought the genuine Suzuki ones which were plain old 30302 bearings and virtually all of the ones I have seen have had plain 30302 bearings in them. I would be interested in whether there are any part numbers on the bearings. Mind you, the seal is going to have little effect as the taper part of the bearing cannot be sealed anyway.
And do you want the bad news, you did not need to undo the hub nut to change the Kingpin Bearings.
Martin.
  • poacher
26 Aug 2010 17:00 #4415 by poacher
Hi Martin,
bear in mind I'm an old landy owner!!
I'll get the part numbers off the old bearings if you want them.
I must say the steering is now as tight as a...................................., well, you get the rest!!
I'm going to have to get a stock of some metric fine nuts & bolts though - 2000 model, things are a bit rusty!!
26 Aug 2010 21:09 #4419 by facade
Replied by facade on topic Re:Parts arrived!!
I bought the rear box, intermediate pipe, conical seal(between the catalyst and intermediate pipe), and gasket ring for the rear box for £66.58 from GT Exhausts over the counter. EBay sellers can beat this, but not if postage is included.
