Valve Timing
  • PhilH
27 Jun 2012 19:45 #43016 by PhilH
Valve Timing was created by PhilH
I have had the head off a 1997 1298 suzuki jimny, cam and all valves and springs out and eventually re-assembled. bottom of engine has not been rotated, but how do I know that I have the cam in the right position to check valve clearances on number one. The lobes on number one are pointing more or less straight up, and number 4 down. is this right for checkingvalves on number 1 cylinder
  • markyp2000
27 Jun 2012 20:20 #43023 by markyp2000
Replied by markyp2000 on topic Re: Valve Timing
if you get no 1 cyl inlet and exhaust rocking ie rotate back and forth inlet should go bown then rotat other way exhaust goes down get it sort of in the middle and adjust cyl 4 then cyl 2 rocking adjust cyl3 cyl 3 rocking adjust cyl 2 cyl4 rocking adjust cyl 1 or there is rule of 9 wich is hard to explain on here
  • PhilH
27 Jun 2012 20:49 #43032 by PhilH
Replied by PhilH on topic Re: Valve Timing
The problem is all the adjusters have been backed right off, so all rockers etc are loose. I just need to know where the cam should be to be able to start with number one then I can be sure I am not 180 degrees out.
  • markyp2000
27 Jun 2012 22:28 #43053 by markyp2000
adjust them up dont matter what to then do the above then all will be good as long as the rockers move when the cam is turned is the head bolted back on the block
Time to create page: 0.092 seconds
