fitting my lift kit (insert expletives)
  • markyp2000
28 Jun 2012 16:52 #43080 by markyp2000
Replied by markyp2000 on topic Re: fitting my lift kit (insert expletives)
on top or the shock there shouls be a flat edge above the nut to get some mole grips on also aply some heat if you can or go to a plum center and get some pipe freeze that might do the trick
28 Jun 2012 17:59 #43083 by robs5230
what do the front springs look like ? is there much bow in the spring due to the axle tilting ? could you post a pic ? i'm looking at changing my suspension as its a bit tired and would just like to see how yours looks. cheers
standard jimny - for now
  • newbiepaul
28 Jun 2012 18:22 #43088 by newbiepaul
Replied by newbiepaul on topic Re: fitting my lift kit (insert expletives)
yeah rob no hassle il post it up tommorow if thats ok as im off to work shortly
28 Jun 2012 19:22 #43093 by robs5230
nice one
  • nicho
03 Jul 2012 19:29 #43471 by nicho
one front lower shock bolt undone heat undo abit heat undo abit defo need new new nuts n bolts.
