fitting my lift kit (insert expletives)
- newbiepaul
25 Jun 2012 17:31 #42904
by newbiepaul
fitting my lift kit (insert expletives) was created by newbiepaul
Hi guys finally got round to start fitting my lift kit from martin ( 3 inch lift ,rough country shocks)
well i thought the rears would be the hard one so started there, all bots undone fine apart from one top one that decided to shear the captive nut .....grrrr,but happy to say all back together and bolted up
il attack the fronts
can anyone give me any advice or hints on fitting the fronts ,before tommorow ,heres a pic of the jimny as she sits tonight lol
time for beer said paul
- Dutchjimny
25 Jun 2012 18:06 #42908
by Dutchjimny
Replied by Dutchjimny on topic Re: fitting my lift kit (insert expletives)
the front should be easier :laugh: good luck
- newbiepaul
25 Jun 2012 18:10 #42909
by newbiepaul
Replied by newbiepaul on topic Re: fitting my lift kit (insert expletives)
cheers for that dutch ,i hope so cos at moment im just about finished tearing my hair out lol
- nicho
25 Jun 2012 19:42 #42915
by nicho
Replied by nicho on topic Re: fitting my lift kit (insert expletives)
snap ive just got my 2 inch rear springs on,didt have time to do the shocks but its a bit tight undoing the top shock bolt init.hope it dunt snap like yours did.im the same any advice on doing the front.
25 Jun 2012 20:13 - 25 Jun 2012 20:38 #42917
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: fitting my lift kit (insert expletives)
Fitting a 2"(50mm)or 3"(75mm) lift.
If you got a set of longer brake hoses fit them first this is only with the 3"lift, not needed on the 2" lift.
You will need to fit some rear shock brackets, If you think you need them you can also fit a set of caster correction + adjustable pan-hard rods.
Next (WD 40) all the nuts and bolts on the shocks for about 2 days before starting.
Start with the rear first axle,undo the wheel nuts a little,then jack up on the axle or the chassis on both sides and lower on to axle stands as near to the radius arms as possible , so the tyres are about 2" off the ground,now remove the wheels.
Next place the trolley jack in the middle of the rear axle, jack it up so you can remove the nuts+bolts from the shocks.
Next lower the axle down keeping an eye on the brake pipe,(don't over stretch it if you are fitting the 2" lift.) next remove the old springs+shocks, you might need a mate to help you fit the new springs+shocks back on, or as l did a length of wood just to lever the axle down a little to get the new springs on.
Now do the the front the same way as the back, you will need to undo two bolts on the anti roll-bar.
If you need the axles to drop a little more you will need to remove one of the panhard rod bolts.
When your finished CHECK all the nuts +bolts+ wheel nuts are tight.
Hope this helps.
DIRTYDOGZ.
Hope this helps.
DIRTYDOGZ.
2002 JLX Soft Top
Last edit: 25 Jun 2012 20:38 by dirtydogz.
- nicho
25 Jun 2012 20:33 #42921
by nicho
ta never thought about a,r,b.
Time to create page: 0.217 seconds
