Fitting Radius arm bracket Guards/Armour
  • myers647
14 Jun 2012 16:56 #42343 by myers647
Hi I just got some Radius arm bracket Guards. They fit just with the single bolt as Im sure you all know,My question is do I need to jack the Jimny up to remove the bolt or can I do it with the Jimny sat on the floor? :huh:
Thanks
James
14 Jun 2012 17:29 #42346 by j999pre
I jacked mine up and put an able stand under the axle and one under the chassis. Then you can wiggle the arm to get the bolt hole to line up again.
Grey pick up Jimny
  • supergaz
14 Jun 2012 17:34 #42347 by supergaz
Replied by supergaz on topic Re: Fitting Radius arm bracket Guards/Armour
I just did mine on the floor as access underneath is easy with the lift.
You might struggle to get the bolts through and it needs a little prodging and the help of an impact gun is desirable.
You might have also got 2 more smaller bolts, I fitted these to the rear guards.
  • renard38
14 Jun 2012 17:48 #42348 by renard38
Replied by renard38 on topic Re: Fitting Radius arm bracket Guards/Armour
[img
  • myers647
14 Jun 2012 18:07 #42352 by myers647
Replied by myers647 on topic Re: Fitting Radius arm bracket Guards/Armour
Thats easy thenthis may be a really stupid question but what are the Lugs for on the ends of the Armour brackets. Iv not even put them up to the car yet to have a look??
Thanks
James
  • supergaz
14 Jun 2012 21:21 #42374 by supergaz
The lugs line up with holes in the chassis rails. The guards are front left and right, rear left and right, so are all different.
If it don't fit then try another. The lugs locate the guards and they give added strength.
DON'T go cutting them.
Its one of my favorite mods, and i'd recommend them on a standard jimny if used lightly off road. :-)
Time to create page: 0.114 seconds
