axel stands
  • nicho
10 Jun 2012 17:20 #42131 by nicho
axel stands was created by nicho
215 80 muds on and after fitting my 2inch lift kit,tryed other day with springs but just couldt get them in need spring compressers,old standard ones came out.im thinking axel stands would be usefull but will normal ones be high enough to do jobs like that on the jimny.ta.
  • Smoggy
10 Jun 2012 18:40 #42138 by Smoggy
Replied by Smoggy on topic Re: axel stands
Dunno if this is the answer Nicho but I've glued 9 x 18'' lengths of 4'' x 2'' together, then sandwiched this between two 18'' x 18'' pieces of 3/4'' ply to make a raft. Done this twice to make two 'rafts' for the axle stands to rest on.
  • darthloachie
10 Jun 2012 20:53 - 10 Jun 2012 20:54 #42144 by darthloachie
Replied by darthloachie on topic Re: axel stands
try taking the damper off at the bottom mount - it will allow the axle to drop further - we got +3" and 2" spring spacers in this way
Last edit: 10 Jun 2012 20:54 by darthloachie.
  • dirtydogz
10 Jun 2012 21:26 - 13 Jun 2012 20:34 #42146 by dirtydogz
Replied by dirtydogz on topic Re: axel stands
Fitting a 2"(50mm)or 3"(75mm) lift. B)
If you got a set of longer brake hoses fit them first this is only with the 3"lift, not needed on the 2" lift.
You will need to fit some rear shock brackets, If you think you need them you can also fit a set of caster correction + adjustable pan-hard rods.
Next (WD 40)all the nuts and bolts on the shocks for about 2 days before starting.
Start with the rear first axle,undo the wheel nuts a little,then jack up on the axle or the chassis on both sides and lower on to axle stands as near to the radius arms as possible , so the tyres are about 2" off the ground,now remove the wheels.
Next place the trolley jack in the middle of the rear axle, jack it up so you can remove the nuts+bolts from the shocks.
Next lower the axle down keeping an eye on the brake pipe,(don't over stretch it if you are fitting the 2" lift.) next remove the old springs+shocks, you might need a mate to help you fit the new springs+shocks back on, or as l did a length of wood just to lever the axle down a little to get the new springs on.
Now do the the front the same way as the back,you will need to undo two bolts on the anti roll-bar
When your finished CHECK all the nuts +bolts+ wheel nuts are tight.
Hope this helps. ;)
DIRTYDOGS. :woohoo:
Last edit: 13 Jun 2012 20:34 by dirtydogz.
  • Smoggy
11 Jun 2012 05:59 #42153 by Smoggy
Oops sorry think I misread the thread. :)
Time to create page: 0.091 seconds
