Which Engine?
  • Jimnyash
04 Jun 2012 16:51 #41737 by Jimnyash
Which Engine? was created by Jimnyash
I've not yet got my Jimny, but will be getting one as soon as I can sell my current car.
Just a very quick question to start with:
Which engine?
The 1298cc early engine or the 1328cc VVT engine?
Are there any major pros/cons of each engine?
Thanks for any info in advance.
04 Jun 2012 18:36 #41748 by facade
Replied by facade on topic Re: Which Engine?
The VVT does more to the gallon than the twin cam which does a little bit more than the single cam.
The VVT is the best choice, but I think it comes as standard with the push button transfer box.
Get a Jan 2001 X plate hard top, comes with twin cam and cheaper tax.
  • Jimnyash
04 Jun 2012 18:40 #41750 by Jimnyash
Replied by Jimnyash on topic Re: Which Engine?
Ah, thanks.
So it's better to have the manual 2wd/4wd selector rather than the push buttons?
Is there any easy way to tell the difference between the twin cam and single cam engines/models?
Just need to sell the current motor and I'll be hunting. Looking forward to it (but reading this forum sends £££££ in front of my eyes!)
04 Jun 2012 19:02 #41753 by facade
If it has push button transfer it is a VVT (the push button transfer is not well liked but it works)
If it is a soft top, it is most likely a single cam.
If it is an "X" possibly, definitely "Y" or later hardtop it is a twin cam.
If you look at the engine, the twin cam has a flat black plastic cover in the centre that says suzuki something or other and the oil filler on the right front as you look at the engine.
The single cam has a ribbed top cover and the oil filler in the centre front.
www.bigjimny.com/index.php/information/f...ntly-asked-questions
  • Jimnyash
05 Jun 2012 05:45 #41764 by Jimnyash
Thanks for the link to the FAQ.
That's great.
In your earlier post you describe three engines, but there are only two on the FAQ. Is the VVT engine the DOHC engine or is one missing from the FAQ?
  • supergaz
05 Jun 2012 08:08 #41766 by supergaz
Replied by supergaz on topic Re: Which Engine?
The VVT is an upgraded M13a DOHC
Time to create page: 0.101 seconds
