what is cold welding
- markyp2000
- vitara_mad
- Rockwatt
But what rob is talking about would be spot weld quench method.
Do a spot weld for just long enough for it to penetrate then with a wet rag quench it (this would normally harden the metal ) then do another spot slightly overlapping the first then quench and continue right along the seam then when you get to the very last spot don't quench ! Just let it cool.
Each following spot aneals the previous one and normalises it so the weld doesn't go brittle from the quenching.
We used to use the method years ago for bodywork and achive a full seam with no distortion.
Well I assume that's what rob is referring to but I'm sure he will be along to correct me if I'm wrong.
Just one point though ! Welding a truss on top of the axle encourages it to bend so it would be much better mounted under it.
- markyp2000
Rockwatt wrote: When you did a google search the you would have found friction fusion welding or ark fusion welding.
if this was the case in your last sentence why would rob have put it on the top shorly he would have made one on the bottom seeing that he is very good at what he does and no dought would have thought the same thing
- Rockwatt
markyp2000 wrote: if this was the case in your last sentence why would rob have put it on the top shorly he would have made one on the bottom seeing that he is very good at what he does and no dought would have thought the same thing
A: it is the case
B: I don't know
Truss on top, when the axle tries to bend it stretches the tube and in extreem cases splits it !
Truss on bottom , when the axle tries to bend it tries to crush the tube along it's length.
Any steel tube takes upto 4 times more presure to crush than it does to pull and snap.
Also when you weld any truss on it pre stresses the axel tube in the direction of the truss so it is pulling it in the direction it's trying to bend. And even when the truss is welded under side the truss needs a greater yeald strength than the axle or it will split the truss first.
Just general structuring engeneering rules.
So it's your choice if you want to act on my advice. My advice is free and so is your choice.
- markyp2000
