hand throttle
  • rooster
15 May 2012 22:18 #40376 by rooster
hand throttle was created by rooster
hi guys , has anyone fitted a hand throttle or does anyone know if it is legal / mot worthy. thanks
  • Rockwatt
15 May 2012 23:02 #40378 by Rockwatt
Replied by Rockwatt on topic Re: hand throttle
A hand throttle is legal "but" not like you want
To fit as it must be spring return.
If you only basically want to increase the tickover to about 1500rpm like I did then an easy way is do it Is with some pipes and a lever valve and use them to bypass the throttle body like the cold air bypass does.
  • meanbgreen
15 May 2012 23:44 - 15 May 2012 23:45 #40380 by meanbgreen
Replied by meanbgreen on topic Re: hand throttle
For my manual on those hill climbs I have done this:
took a bike lever mounted it to the stick then ran the cable to the gas pedal.
Last edit: 15 May 2012 23:45 by meanbgreen.
  • adamjimny
16 May 2012 09:45 #40404 by adamjimny
Replied by adamjimny on topic Re: hand throttle
Iv got a hand throttle mounted on the gear stick and no problems at a strict MOT station
sent from my Samsung Galaxy S2 using Tapatalk
Time to create page: 0.085 seconds
