so what do guys want ?
  • vitara_mad
03 Jul 2012 07:48 #43430 by vitara_mad
Replied by vitara_mad on topic Re: so what do guys want ?
j999pre wrote: Spacer to retain standard jimny rear prop when fitting a rock lobster.
Or is the little cv joint on the jimny rear prop seen as a weak link?
theres already 1 of them been made
  • Rockwatt
03 Jul 2012 08:04 #43432 by Rockwatt
Replied by Rockwatt on topic Re: so what do guys want ?
That's easy but a wast of time ! The cv only has an angle capacity of 6 degrees before it reduces strength to 1/3.
A uj is much better suited. The cv was put on there for more civilised road use but useless once you ad a lift. And also the plunge doesn't give enough travel compared to the splined slip of a conventional prop.
03 Jul 2012 15:00 #43441 by Obarno
Replied by Obarno on topic Re: so what do guys want ?
I have a spacer on my auto that allows the use of the Jimny std rear prop and so far it works fine. It does give a less harsh drive line, and on my car anyway, the prop is very nearly in line ie without large angles at either end. The ERM kit uses a new flange for the std Jimny rear prop to fit to and from the use/abuse I have seen them take it doesn't seem to be a problem in terms of breaking the cv joint. I suppose the ideal would be a double Cardan joint at the transfer box end. Better still would be a rear prop that used bigger ujs as the small Suzuki ones wear quickly with a low ratio transfer box.
Trouble is where does it all end??!!
  • Rockwatt
03 Jul 2012 15:10 #43442 by Rockwatt
Obarno wrote: I have a spacer on my auto that allows the use of the Jimny std rear prop and so far it works fine. It does give a less harsh drive line, and on my car anyway, the prop is very nearly in line ie without large angles at either end. The ERM kit uses a new flange for the std Jimny rear prop to fit to and from the use/abuse I have seen them take it doesn't seem to be a problem in terms of breaking the cv joint. I suppose the ideal would be a double Cardan joint at the transfer box end. Better still would be a rear prop that used bigger ujs as the small Suzuki ones wear quickly with a low ratio transfer box.
The ideal ones are Toyota surf rear props shortened to fit, they have the same bolt patern they are wider angle and much stronger. They only need the register on the flanges increased by 1 mm and they are then bolt on.
  • frede.gv1
03 Jul 2012 15:34 #43443 by frede.gv1
Replied by frede.gv1 on topic Re: so what do guys want ?
a pto on the org transfer is on my list. could make a really fast winch.
03 Jul 2012 16:53 #43449 by j999pre
Replied by j999pre on topic Re: so what do guys want ?
Cheers for the prop info. I have a sj front prop but it needs a uj.
I'd better crack on and get one then!
Grey pick up Jimny
Time to create page: 0.216 seconds
