so what do guys want ?
30 Jun 2012 08:59 #43220
by Obarno
Replied by Obarno on topic Re: so what do guys want ?
Hi Rockwatt
Just wondered if you are any closer on deciding which ideas you can take forward, or which are even viable?
- Rockwatt
30 Jun 2012 11:01 #43224
by Rockwatt
Replied by Rockwatt on topic Re: so what do guys want ?
I'll be attacking most of them even the wheel arches but over the next few months I'll be moving and building a custom built workshop. So I'm in limbo for a little while.Obarno wrote: Hi Rockwatt
- markyp2000
30 Jun 2012 14:54 #43233
by markyp2000
Replied by markyp2000 on topic Re: so what do guys want ?
I think he means VOSA who are ever present at the side of the roads these days!
What did they say if the vehicle is not used for race of competition though and is just for playing like wot I does - how should the tester view it then?
Some of these rules are starting to get to be a pain in the back side!!!
Kirkynut[/quote]
alright then modified for offroad/race use but need to be road legal in other ways
Kirkynut[/quote]
01 Jul 2012 14:02 - 01 Jul 2012 15:07 #43301
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: so what do guys want ?
A bracket that is drilled so that it bolts on to the front chassis brackets so you can use the original arms and bushes , so you don't need to fit correct bushes on a 2"+3" lift.
+ brackets that bolts on to the chassis with holes drilled, for the front and back pan hard rods from 2" to 3" so you can use the original rods as fitted to Panosd jimny.
2002 JLX Soft Top
Last edit: 01 Jul 2012 15:07 by dirtydogz.
- markyp2000
01 Jul 2012 14:50 #43307
by markyp2000
im liking that mod lots
:laugh:
:woohoo:
- blakey2000
02 Jul 2012 11:24 #43383
by blakey2000
Replied by blakey2000 on topic Re: so what do guys want ?
what about a new bracket for fitting the steering stabilizer/damper/RTC to the tie rod and axle rather then the steering arm and chassis? as i have been told it is a better way to have it fitted / works better
Time to create page: 0.245 seconds
