so what do guys want ?
  • adamjimny
13 May 2012 20:22 #40165 by adamjimny
Replied by adamjimny on topic Re: so what do guys want ?
I want some higher shock mountings and also some radius arms that allow twist so i can get and make use of some dislocation cones
sent from my Samsung Galaxy S2 using Tapatalk
  • darthloachie
13 May 2012 20:41 #40169 by darthloachie
Replied by darthloachie on topic Re: so what do guys want ?
front radius arms that will fit over the axle but still fit existing brackets on the axle to avoid the digging in you get but will still take wheels in the air abuse
wide angle hd propshafts with multi-fit end flanges for use with rocklobsters and big lifts
multi fit - two sets of holes (like on aftermarket alloys) for the transfer box end that will fit either 410 or 413
13 May 2012 20:57 #40174 by facade
Replied by facade on topic Re: so what do guys want ?
oxford_bloke wrote: smoggy,
as far as anti roll bars go, take it of grind down the brackets and it will pass. i have done this on a couple of cars and taken it to strict MOT places and no isssues at all they can only fail what is there not what isn't
tom
Bad advice I'm afraid. If it left the factory with one fitted it will fail if it doesn't have one when presented.
2012 Testers Manual Section 2.4 G
Reason for failure
"A suspension component or its attachment bracket or linkage:
missing where one is fitted as standard"
Same thing for steering locks
Airbags
Belt pretensioners
However, you are allowed to remove the entire ABS system if you like.
  • Rockwatt
13 May 2012 22:28 #40193 by Rockwatt
Replied by Rockwatt on topic Re: so what do guys want ?
Thanks for the Feedback.
Alternator mount, to add
Flex radius arms + spring dislocation , already in development. fully bolt on
Uprated tie rod, to add
Multi hole transfer flanges, my Sj cases come with then as standard
wide angle props, already do them. Custom to order.
Alloy tree sliders, do you mean like the landy type ? Just below window line !
Anti roll bar disconnects, to add
Diesel conversion. Not to add. To many engine choices, to many variables in the engines. To cover them I would need to fit about 30 different engines just to get a kit that was anywhere near universal. There is also radiators. Intercoolers, Fuel tanks, reduction starter motors ,
IMO the only engine that comes close to a suitable weight for a Jimny is the zuzu lump and not many people want to use them, preferring the pug/vw lumps.
Anything else ?
  • jo king
13 May 2012 23:07 #40200 by jo king
Replied by jo king on topic Re: so what do guys want ?
Yes purpose built bolt on fitment of a pair of portal axles with electric locking diff and low geared to fit a standard jimny using standard springs. All for under 2k or cheaper.
  • Rockwatt
13 May 2012 23:32 #40202 by Rockwatt
jo king wrote: Yes purpose built bolt on fitment of a pair of portal axles with electric locking diff and low geared to fit a standard jimny using standard springs. All for under 2k or cheaper.
No problem ! How about a pair of atomic axles instead (google it )
You have got to be jo king wah hah hah
