SJ Modified front axle
- Smoggy
- Visitor
What I don't understand is how the 4WD is selected without the use of vacuum system or manual locking hubs.
Thanks in advance guys.
- vitara_mad
- Visitor
- Smoggy
- Visitor
- reaper
- Visitor
- vitara_mad
- Visitor
the only thing with fixed hubs is even in 2wd when driving the wheels are still turning the front shafts,diff & front prop but theres no drive to them so that no problem
some sj's & vits come fitted with fixed hubs as standard so no need to worry & theres nothing to go wrong with fixed hubs
the only downside is if you break a front shaft or cv you cant disengage front hubs but you can just unbolt the fixed hub to drive home
- Smoggy
- Visitor
- Smoggy
- Visitor
- vitara_mad
- Visitor
- vitara_mad
- Visitor
Smoggy wrote: Forget last post thanks.
ok forget my last post as well then :laugh: :laugh: :laugh:
- reaper
- Visitor
Fixxed hubs - when in 2wd the hubs turn the diff and props but the t-box isnt turning the output drive
- Smoggy
- Visitor
vitara_mad wrote: yes you still have 2wd as when you select 2wd on transfer box theres no drive to the front output on the transfer box
Would hope I wont break them as theyre chromoly 4340, mind you with 33 x 11.5s you never know
- Smoggy
- Visitor
