External cage extra weight
- TomDK
25 Apr 2012 18:38 #38590
by TomDK
Replied by TomDK on topic Re: External cage extra weight
As I mentioned above. One thing to consider, the extra protection of an internal cage has diagonal tubing which adds loads of strength. A external cage has none of this. So it's more for the looks and some body protection than real protection if the car rolls over or worse.
- supergaz
25 Apr 2012 19:49 #38606
by supergaz
Replied by supergaz on topic Re: External cage extra weight
I have a KAP external cage, I do plan to fit a diagonal through the car. I believe Martin has done this.
25 Apr 2012 19:55 #38608
Replied by mlines on topic Re: External cage extra weight
Yes mine has a Kap external cage with an internal cross brace.
On its own the Kap cage, which welds underneath to the chassis rails, has too much flex and the car body hits the cage as it flexes. I have a flat plate welded to the central roof rollcage cross bar and this then bolts through to a flat plate inside the car where a cross brace goes through down to the chassis rail.
Sent from my HP Touch pad using Tapatalk
- Smoggy
25 Apr 2012 20:06 #38614
by Smoggy
Replied by Smoggy on topic Re: External cage extra weight
Im very intersted in exactly how youve done this Martin. Any chance you could post some pics please.
26 Apr 2012 07:52 #38634
Yes, will do. Reminder me if I forget!
The following user(s) said Thank You: Smoggy
26 Apr 2012 08:58 #38637
by kirkynut
Replied by kirkynut on topic Re: External cage extra weight
My Jimny would be a write off by now without an external cage.
You have to ask yourself what you want the cage for and get one made for that purpose.
If you want a cage to keep the trees off your shell - they will quickly write it off - you need an external cage.
If you want a shell that will save just you and your occupants but not the car in a roll and don't care about writing off your shell on trees, you want an internal cage.
If you want a cage that will keep the trees off youe shell and leave it relatively dent free and that will protect you and your occupants you want an external cage that has internal bracing through a sandwich plate in the roof and floor like Martin's or both an internal and an external cage both joined together through the roof and sandwich plates.
I would pop along to a local top level challenge event or a 4x4 garage that prepares people's car for top level challenge events - even if they are cars from the dark side and see how they do it.
Challenge trucks need lots of external protection and good protection for the occupants, so they have it all.
In the UK, a large number of offroad sites run through woodland and the trees like to play games with us offroaders and jump out into us!
Stuff the weight, consider how much a good second hand Jimny is when your roof is bent!
Mine only has an external cage and has been on it's side with minimal damage and my cage did flex and just kissed the bodywork.
When I drive the sites I go to, I think about what I'm doing before I drive bits and if I could go over. So far the only risk of going over has been up a steep hill and going over backwards. On those occasions I've used the winch on the front to prevent this, even if I could have driven it.
I am considering internal bracing but don;t want to loose my rear seats, so I'm considering a single diagonal bar which could be removable.
Time to create page: 0.168 seconds
