HD Halfshafts and CV's
  • Rockwatt
09 Jun 2012 19:14 #42088 by Rockwatt
Replied by Rockwatt on topic Re: HD Halfshafts and CV's
bluejimny wrote: did a little on the shims to fit the larger CV's
the plan is going with TG ones, and yes with a bit of die grinding they will fit, as they are quite larger i plan to bring the stub out with a spacer
from testing they seem to need 5mm either side to get the cv clearance
then just machine the end of the TG CV to suit the jimny and what ever hub is being used as they are longer than the jimny ones
If your spacing them out don't overlook that the pivot point of the cv needs to be perfectly in line with the king pins or you will kill axle seals and hub sleeves in double quick time.
  • bluejimny
10 Jun 2012 11:15 #42125 by bluejimny
Replied by bluejimny on topic Re: HD Halfshafts and CV's
all ready sorted, cheers :)
  • supergaz
10 Jun 2012 20:09 #42141 by supergaz
Replied by supergaz on topic Re: HD Halfshafts and CV's
When you going to start testing Rus? 17th Silverdale?
  • bluejimny
10 Jun 2012 20:32 #42143 by bluejimny
hopefully silverdale or tickhill in july, just going pop in a front ARB while ive got everything stripped down, for some testing B)
  • darthloachie
10 Jun 2012 20:57 #42145 by darthloachie
Replied by darthloachie on topic Re: HD Halfshafts and CV's
see you on the 17th :)
  • supergaz
10 Jun 2012 21:28 #42147 by supergaz
darthloachie wrote: see you on the 17th :)
Yurp, sounds good to me! :woohoo: :woohoo:
Time to create page: 0.221 seconds
