Hello
- Knight.
16 years 4 months ago #3797
by Knight.
Hello was created by Knight.
Just popped in to say hi and have a nose around.
Have a friend who has offered there jimny to me for a grand, so just trying to find out wether its worth it for offroading and the odd commute to work. Getting rid of my LJ80
He is a bit dumb every time somthing goes wrong he puts into Mitsubishi main dealer to get it fixed and is no giving up on off roading :huh: last straw for him was four wheel drive has stopped working, i'm thining i may be able to fix this myself.
16 years 4 months ago #3801
by kirkynut
Hi there,
A grand is a steal unless it is particularly knackered!
In standard form they are not much cop off road but with a suspension lift and some bigger tyres Jimny's are ace.
The 4wd not working is probably just the vacuum operated front free wheeling hubs - bin them and get some SJ/Vitara manual free wheeling hubs and either cut down the front wheel bearing nuts or buy a pair of spacers from this website's shop to make them fit and you're laughing.
You can use the fixed hubs from an SJ instead if you want. They will be cheaper but the front diff will always be spinning causing un-necessary wear and more fuel usage.
Do it - you know it makes sense ...
- Knight.
16 years 4 months ago #3812
by Knight.
Replied by Knight. on topic Re:Hello
Got it for a grand
will post details soon.
16 years 4 months ago #3816
As Kirkynut says, 4WD failures are straight forward to cure but a great bargaining point against sellers who do not understand.
Good luck with the new car but why are you selling the LJ, this is rapidly getting classic status!
- Knight.
16 years 4 months ago - 16 years 4 months ago #3818
by Knight.
I need some thing that i can use all year round and to get to work in the winter.
Classic yes i would say so, and look i have two on my drive
also very hard to get hold of, the one on the letf i have borrowed off a friend which i have been using for the three months for a refrence and drive every now and then
the one on the right is mine a project started but one i will not finish
i put an SJ410 engine in moved battery and fuel tank to the rear cut down the doors.
Going to refurb the wheels on the one on the right and attempt to put them on the Jimny
Last edit: 16 years 4 months ago by Knight..
- Knight.
16 years 4 months ago #3819
by Knight.
Time to create page: 0.094 seconds
