Wheel Spacers
- myers647
- Visitor
13 Apr 2012 21:32 #37489
by myers647
Replied by myers647 on topic Re: Wheel Spacers
Hi mate,
I've got the 32mm Grayson spacers fitted, and its made it a lot better in my opinion. I had the car for about 9 months without them and it jumped all over the road at every little bump, its now quite stable and with the bigger tyres its stable on the motor way at 65-70mph, With my lift and big tyres. So yes I would definitely recommend them to anyone with a Jimny. All so better when off road as its got a wider track and makes it easier to run in the big tracks that the big crappy LR's make.
Thanks
James
Thanks
James
- happypig
- Visitor
14 Apr 2012 08:49 #37527
by happypig
Replied by happypig on topic Re: Wheel Spacers
Do you need to fit wider arches if you fit spacers (standard AT tyres, steel wheels) ?
- reaper
- Visitor
14 Apr 2012 09:08 #37532
by reaper
Replied by reaper on topic Re: Wheel Spacers
Depends on tyres you run but to be "legal" the tread of the tyre should be inside the arch ,
You can fit bushwackers they are simple and cheep to make
- Juggernaut
- Visitor
14 Apr 2012 09:25 #37536
by Juggernaut
Replied by Juggernaut on topic Re: Wheel Spacers
Is that safe? Driving without a sway bar?
- darthloachie
- Visitor
14 Apr 2012 13:48 #37556
by darthloachie
it just leans more through the corners so you have to go a bit slower but it improves off road ability no end
Replied by darthloachie on topic Re: Wheel Spacers
Juggernaut wrote: Is that safe? Driving without a sway bar?
14 Apr 2012 14:13 #37558
by Halford
Replied by Halford on topic Re: Wheel Spacers
Also got the 32mm Grayson spacers fitted, and its made it a lot better - so much more stable, both straight line (no more road meandering) and cornering, even the harshness over potholes and speed bumps appears softened.
see the DogTaxi write-up
nah they're OKDo you need to fit wider arches if you fit spacers (standard AT tyres, steel wheels) ?
