Wheel Spacers
  • darthloachie
  • Visitor
  • Visitor
18 Apr 2012 20:19 #37960 by darthloachie
Replied by darthloachie on topic Re: Wheel Spacers
theres another set on ebay but no bolts so fairly useless
they're £66 new from either jimny bits or bits4vits
  • Carrow
  • Visitor
  • Visitor
19 Apr 2012 18:48 #38024 by Carrow
Replied by Carrow on topic Re: Wheel Spacers
Well I finally went for the grayston spacers, look like a sturdy bit of kit, thanks for all your help, can anyone tell me how tight the lug extenders need to be, I am using a ring spanner to align them up, as my torque wrench doesn't fit them.
Cheers.
  • supergaz
  • Visitor
  • Visitor
19 Apr 2012 19:18 #38027 by supergaz
Replied by supergaz on topic Re: Wheel Spacers
Id get a socket to fit your torque wrench, tighten them to the spec stated on the instructions, then tweak them accordingly to align them.
19 Apr 2012 19:50 - 20 Apr 2012 05:23 #38031 by Halford
Replied by Halford on topic Re: Wheel Spacers
Hi Carrow
the technique is to "tighten" them using the spanner (applying bit of arm pressure - but not forcing it), then you'll need a final tweek to align them so the castings will slide over - involves tapping the spanner with an hammer
Last edit: 20 Apr 2012 05:23 by Halford.
  • Carrow
  • Visitor
  • Visitor
19 Apr 2012 20:02 #38033 by Carrow
Cheers thanks for all your help.
19 Apr 2012 20:06 #38034 by j999pre
Replied by j999pre on topic Re: Wheel Spacers
BIG-P wrote: gutted was at work and missed the ending :angry:
Sorry mate :dry:
Grey pick up Jimny
  • Carrow
  • Visitor
  • Visitor
24 Apr 2012 17:15 #38494 by Carrow
Hi,
Finaly got round to fitting the spacers to-day, I torqued them to 70ft/per lb as per intructions, but found I had to undo them (tweek) them to final position, one of the lug extenders is only nipped up to get it to align, other wise I have to over tighten it past 90ft/lb, will this be ok.
Spacers are Grayston 32mm
24 Apr 2012 17:27 #38495 by Halford
personally, I'd have thought it'd be OK as long as it is actually nipped.
It's not going to loosen - because the casting spacer ring won't let it.
but don't take my word for it, let's see what others have to say about :unsure:
Don't know what torque is on mine, but is probably HIGH as mine were tapped on with the hammer :pinch:
The following user(s) said Thank You: Carrow
24 Apr 2012 17:29 #38496 by j999pre
Should be. As a precaution you could orientate the spacer over that nut so that it has one of the hexaganol holes over it rather than the larger slotted hole. That way it is held in place firmly by the spacer on all six sides of the extender nut.
I hope that makes sense.
I took my spacers off at Briercliffe this weekend as my wheels were making contact with the front bumper. I may sell them yet or trim the bumper. A bit undecided. Hmmmm :dry:
Grey pick up Jimny
  • reaper
  • Visitor
  • Visitor
24 Apr 2012 17:35 #38500 by reaper
Replied by reaper on topic Re: Wheel Spacers
Trim the bumper bud :)
I have a massive blood blister from fitting mine saturday ....as my dad would say "dont put your fingers where you wouldnt put your c#*k "
24 Apr 2012 17:39 #38501 by Halford
:laugh: :laugh: stop biting your nails then Reaper.
put a bumper like Monkey's on
24 Apr 2012 17:45 #38502 by j999pre
I like that bumper. Could be the way forward.
Grey pick up Jimny
Time to create page: 0.156 seconds
