rocklobster
- darthloachie
28 Jun 2010 10:53 #3694
by darthloachie
rocklobster was created by darthloachie
If you have a rocklobster transfer box fitted does that mean as it is a transfer case from an sj that the rear propshaft is also from a sj rather than a jimny? (the propshaft on now splits apart just after the transfer box on splines)
28 Jun 2010 10:56 #3695
Replied by mlines on topic Re:rocklobster
It depends on who's mounting kit you have used to mount the Rocklobster. Different kits use different solutions. I used the Offroad Armory Kit and it used the FRONT prop from an SJ as the new REAR prop
- darthloachie
28 Jun 2010 19:12 #3699
by darthloachie
Replied by darthloachie on topic Re:rocklobster
I don't know, I'll have to try to find out from the previous owner
Thanks Martin
Thanks Martin
29 Jun 2010 13:47 #3702
by kirkynut
Replied by kirkynut on topic Re:rocklobster
Mine is from Rockwatt and uses the same as Martin's!
Rob
Rob
- darthloachie
29 Jun 2010 16:32 - 29 Jun 2010 16:43 #3707
by darthloachie
The rocklobster mounting kit was by rob storr and had been fitted before the previous owner bought it. it was at one time Stuart Bell's (see other jimnys) and it had the rocklobster on then (2008) so it has lasted a while including winch trials by the previous owner
Here are some more pics of the bits - any one know which one it is? front or back sj 413 or 410?
Last edit: 29 Jun 2010 16:43 by darthloachie.
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
01 Jul 2010 09:20 - 01 Jul 2010 15:39 #3713
by funkyjimny
Replied by funkyjimny on topic Re:rocklobster
Rob Storr makes the props out of a jimny prop and an SJ prop, best give him a ring 07815 182857. Hes notoriously hard to get hold of and even harder to pin down to doing a job for a particular time, but his work is absolutley A1. If you dont have any joy with Rob Storr then ring Richard Wattam (Rockwatt)(PM me for number) (and tell him i sent you) and he could make you a prop up if you give him the distance between the two flanges. I'd bet both would need you to supply some props though.
Gary
Gary
Last edit: 01 Jul 2010 15:39 by funkyjimny. Reason: Rich didnt want his phone number posted up!
Time to create page: 0.105 seconds
