Wheel Spacers
  • doomhouse
31 Mar 2012 09:47 #36643 by doomhouse
Wheel Spacers was created by doomhouse
Fitted some billet alloy wheel spacers the other day. Car looked awsome. Went for a drive. Hit about 25 30 mph and got the dreaded death wobble, So bad, I had to stop and check all the wheel nuts were still tight. ( everything ok ) . Limped home and removed the wheel spacers. Went out for a drive and everthing ok, no wobble. Car has just had a full service and mot and no problems found. Would realy like to fit the spacers again but too dangerous. I have been to tong pay and play and seen many jimnys with spacers.
Any ideas anyone? :(
  • adamatdraycott
31 Mar 2012 10:52 #36645 by adamatdraycott
Replied by adamatdraycott on topic Re: Wheel Spacers
Could well be added load on nearly knackered kingpin bearings/wheel bearing
I personally think wheel spacers cause more harm than good
  • mcjimny
31 Mar 2012 11:58 #36646 by mcjimny
Replied by mcjimny on topic Re: Wheel Spacers
Could be a combination of the kingpins and a wheel out of balance. The wheel may not be apparent so severely until you add the extra distance from the hub.
Try swapping front to back and see if it improves. I sit on the fence where spacers are concerned, personally i prefer offsets but i'm considering spacers for my stock rims for daily use.
  • dirtydogz
31 Mar 2012 15:58 #36652 by dirtydogz
Replied by dirtydogz on topic Re: Wheel Spacers
I agree with McJimny,so sell the wheel spacers, buy some wheels with a bigger offset like the 7x15 modular your 205/70/15 will fit on them ok. B)
  • supergaz
31 Mar 2012 18:02 #36655 by supergaz
Replied by supergaz on topic Re: Wheel Spacers
My 32mm Greyston wheel spacers improve the handling on mine, also I have bigger off-set rims.
If I put my unbalanced (rears) on the front then the jimny wont go over 20mph without doing back flips.
01 Apr 2012 01:45 - 01 Apr 2012 01:46 #36670 by Halford
Replied by Halford on topic Re: Wheel Spacers
32mm spacers on mine, love them, handling and ride is so much better. :)
I've got the death wobble ever so slightly, but not sure whether that's due to the spacers or the 10mm lift afforded by my ATs.
But you haven't got the death wobble, that doesn't start until 43mph ish.
start by simply getting your wheels balanced - you don't by any chance have the dreaded 3 spoke alloys fitted do you ?
Last edit: 01 Apr 2012 01:46 by Halford.
Time to create page: 0.098 seconds
